Mid-Atlantic (Sales) VA, DC, and MD
$1,400 obo F/s: 100% turn key Ls swap w/ ctr pistons
Old Nov 22, 2012 | 05:40 AM
jdmsupreme2132's Avatar
Default $1,400 obo F/s: 100% turn key Ls swap w/ ctr pistons
Means of contact: 240 620 1708
Price: $1,400
Description: up for sale is my swap. The engine consists of a b18b1 engine block and head. The bottom end has pr3 pistons hung on ls rods and ls crankshaft.
New piston rings
new headgasket
new headbolts
new timing belt
New waterpump
new oil pan gasket
new distributor
New rear main seal
New valve cover gasket set
new clutch (ACT stage 1)
new flywheel (9lb Fidanza)
Gsr trans
shift linkages
axles
This swap only has only approx. 250miles since it was first built. The car it was in was hit and run while parked on the side of the road.
For an additional $100 ill throw in the pheareable chipped p28 w/pacman obd2a to obd1 jumper harness.
turbozcteg
Oct 20, 2006 01:39 PM
boostin4door
Jan 31, 2005 05:59 AM
