EF bogs when I give it gas help please!!!
Old Nov 21, 2012 | 06:16 PM
nycpatron's Avatar
Default EF bogs when I give it gas help please!!!
Trying to help my friend with his Ef. We just did mpfi convertion on it, it turns on an all but now when I hit the gas it bogs and stalls sometimes shuts off sometimes it doesnt sometimes it will shut off a couple of seconds after. If I try to drive it ,it tries to shut off so I let go of the gas so it idles when its cold it works normally but then when it gets warm goes back to the problem.
It has a check engine light
6=colant temp sensor is broken
14=Electronic air control
Has new fuel filter
New ngk spark plugs
New cap and rotor
obd1 injectors
Any ideas? thanks in advanced the car is driving me nuts.
Old Nov 21, 2012 | 06:31 PM
nycpatron's Avatar
Default Re: EF bogs when I give it gas help please!!!
The iac wouldnt cause it to bog like that would it?
The car was sitting for a while before we started it I dont know if that changes anything.
Also forgot to mention sometimes I have to crank it 2 or 3 times for it to start up.
Old Nov 21, 2012 | 07:05 PM
ED3 SEDAN-GSR's Avatar
Did you switch the two outside wires on the throttle position sensor? Also did u by chance switch this plug with the map sensor plug?
Old Nov 21, 2012 | 07:30 PM
nycpatron's Avatar
No I didnt switch the wires the tutorial I followed didnt say that or maybe I missed it...
The tps and the map sensor have their correct plug I checked a couple of days ago at first I was getting a code for the map sensor but it was because none of the vacuum lines where connected I connected them till the motor felt normal but didnt use a diagram ill make sure I check that out tomorrow thanks.
Old Nov 21, 2012 | 09:26 PM
Switch the two wires on the tps. The dpfi works backwards to the mpfi tps.
Old Nov 21, 2012 | 09:30 PM
Former User's Avatar
Fix the CEL codes.
Old Nov 22, 2012 | 06:52 AM
nycpatron's Avatar
Fixed the cels and It still is bogging I noticed that if I try and rev it, it will back fire I dont know if a bad tps will cause that?
It kinda idles perfect but like I said if I accelerate it, it will bog and misfire
sstupid
20
Aug 18, 2016 06:46 PM
skagitstriker15
Feb 9, 2012 03:32 PM
Daniel jdm
12
Jun 17, 2009 08:36 PM
Chico90hb
Oct 5, 2005 09:42 AM
legendboy
Nov 3, 2004 10:57 AM
