Random Low Idle
Old Nov 21, 2012 | 04:12 PM
mimog3's Avatar
10 Year Member
Default Random Low Idle
I Drive a 00 EX Coupe and for some reason when I Stop at a light occasionally will the Idle Drop around 500 RPM'S which causes the car to vibrate a bit, but overall its usually up around 800- 900 RPMS if i had to estimate. I changed the spark plugs, Wires, Distributor Cap and Rotor and recently the Ignition Coil since i burned that out. the new ignition coil seemed to improve idle a lot, but still falls to 500 RPMS occasionally. What should i do?
Thanks
Old Nov 21, 2012 | 04:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Random Low Idle
Nothing. It's normal. Do you notice that it seems to do it when the fan kicks on?
Old Nov 21, 2012 | 04:18 PM
mimog3's Avatar
10 Year Member
Not Sure, Next Time that happens ill try to hear for it. I was thinking maybe i need to change my IACV because sometimes when i cold start my car the idle will bounce three times and think that might have a correlation to the low idle
The Grumpiest
Clean the IACV.
Old Nov 21, 2012 | 04:21 PM
mimog3's Avatar
10 Year Member
I remember last time i cleaned it about 8 months ago, it had no effect. would you recommend that i check anything else, by the way thanks for your help grumblemarc
Old Nov 21, 2012 | 04:36 PM
The Grumpiest
Hm. Test TPS?
Old Nov 21, 2012 | 07:28 PM
mimog3's Avatar
10 Year Member
Ill try to do that tomorrow since ill be off work, do you think possibly cleaning the the throttle body should help as well?
hell0curry
Apr 4, 2012 11:20 PM
abusedvtec
Sep 1, 2009 01:44 PM
thunderlips
Oct 17, 2008 03:19 PM
toastyfishands
Jun 12, 2007 11:29 AM
SOHC_MShue
Sep 29, 2003 07:28 PM
