Car turn on and off
Old Nov 21, 2012 | 08:57 AM
creation25's Avatar
Default Car turn on and off
Hi, I own a 92 civic hatch. My car dies from time to time. Does anybody know what the problem may be? Sometimes I put key in and crank it...works.. go to the store, come back home and park the car.. next day, put key in.. crank.. nothing. I changed my battery 4-5 months ago but I never drive the car, it's been park in the garage since then. Weird.
Old Nov 21, 2012 | 11:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: Car turn on and off
Check/redo the main grounds, [batt. post and cable clamp, batt. to chassis ground and chassis to engine ground] DO NOT just eyeball them, disconnect/clean/reconnect.
Even if the grounds are not your problem, you need to eliminate them as the possible problem, also it can not hurt to redo the grounds on a 20 year old car. 94
Old Nov 21, 2012 | 11:28 AM
creation25's Avatar
I found the problem it was a dead battery I parked the car for too long. Replace battety and works fine now.
Old Nov 21, 2012 | 04:33 PM
fcm's Avatar
fcm
Old Fart
You should still redo the grounds for reasons stated, [20 year old car].94
kwoksturr
Sep 27, 2004 05:20 AM
drkblue_civic
Sep 7, 2003 11:34 PM
OneFastLS
Jul 17, 2002 02:40 PM
flex97itr
Jan 14, 2002 08:23 PM
