91 integra transmission slipping
Old Nov 20, 2012 | 05:25 PM
Ryan Duffney's Avatar
Default 91 integra transmission slipping
looking at a 91 integra auto but the trans slips unless you go very light on the throttle, guy told me that it needs a torque converter but i don't know if i should believe him he also said that when it slips he puts it in park and then can take off again! has anyone ran into this or is he pulling my chain? full of fluid that was the obvious check, could it be the torque converter or is the trans most likely toast?
Old Nov 20, 2012 | 09:00 PM
el crapitan's Avatar
Default Re: 91 integra transmission slipping
drain the fluid into a clean pan. if there is any bronze shimmer, the trans ls likely toast.
if the fluid looks blackish and smells burnt, it could be the torque convertor. however, a bad torque convertor is more likely to shutter.
but if the problem actually does go away if the vehicle is restarted, it's more likely not a mechanical issue, but maybe a problem with the tcm.
checking the tcm for codes would be a good start. if no codes, check the fluid.
could also be a shift solenoid issue.
does the trans actually slip? i mean with increased load, in any gear? or is it more like it's not hitting one specific gear?
Old Nov 21, 2012 | 01:00 PM
it definately slips with more load put on it....how do i check for tcm codes? is there a connecter to jumper across and count the engine light flashes?
Old Nov 21, 2012 | 07:34 PM
has the s3 light been flashing? if the s3 light hasn't been flashing, there probably won't be a code.
also, it sounds more like a mechanical fault as apposed to a control/electrical issue.
i would dump the fluid in a clean pan and inspect
crash85
Dec 31, 2011 10:05 AM
Aqualite_Solid
Apr 15, 2011 09:09 AM
crvb20z
Apr 6, 2009 06:53 AM
MidShipCivic
Honda Civic (2001 - 2005)
Jul 12, 2006 05:35 AM
4ghatch
10
May 13, 2003 08:37 AM
