dpfi to mpfi odb0
Old Nov 20, 2012 | 03:15 PM
dre33333's Avatar
Default dpfi to mpfi odb0
so went to mpfi and i am getting a code 9 i also followed the diagram to swap it from dpfi to mpfi but all the diagrams i am seeing is to swap over to obd1 but i am not trying to. any suggestions on what i might have done wrong
Old Nov 20, 2012 | 03:18 PM
splatranger95's Avatar
Default Re: dpfi to mpfi odb0
There is no difference swapping to OBD1 than doing the OBD0 only swap.
Old Nov 21, 2012 | 10:46 AM
Canadian_EF's Avatar
Other than adding a 4 wire o2 sensor, deleting the resistor box if running obd1 injectors, relocating your map wiring, cross referencing various pinouts for the proper distributor wiring, getting a new distributor and ecu+ jumper harness....
Op, try swapping pin c1 and c2 around.
Old Nov 23, 2012 | 06:59 AM
You are right.... I just did the swap and I guess I forgot about all that.
OemED
19
Oct 10, 2016 08:19 AM
ef9allday
Mar 14, 2012 11:12 PM
Jmar9289
14
Jan 13, 2011 10:25 AM
solohatch
Jul 1, 2005 12:13 AM
thumbtack
Aug 4, 2004 05:51 AM
