Fuse Keeps Burning Out Help!
Old Nov 20, 2012 | 01:48 PM
90DB1TegSedan's Avatar
Default Fuse Keeps Burning Out Help!
So i own a 1990 Acura Integra with a B20B Swap
and recently when i pop my shifter into reverse my Fuse light that controls the Backup lights, and the Dash Gauges ( Gas, Temp, and Rev) dont work and ive had to replace them about 10 times in the past 2 weeks
so any help would be appreciated
Old Nov 20, 2012 | 03:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: Fuse Keeps Burning Out Help!
It is obvious you have a short, [to ground] and because it only blows when you put the car in reverse, the short is in the backup light circuit.
To confirm, unplug the reverse light switch on the transmission. 94
Old Nov 20, 2012 | 05:57 PM
is the switch gonna be on the bottom part or is it something i can access through the top
i do vaguely remember when i was under their a while back changing my steering rack that their was a green cap plug that was loose and i plugged back in(which explained why my backup lights didnt work before) but appeared to be broken..ill take a pick to see if that was it
could that be it if its loose that its shorting?
Old Nov 21, 2012 | 05:37 AM
fcm's Avatar
fcm
Old Fart
A loose connection is not a short.
What transmission do you have?
On a stock manual 90 Integra the switch is located on the lower front pass. side of the transmission...
It is a 2pin switch with a green/black lead and a yellow lead, the probem is most likely someplace along the green/black lead, [runs from the switch to the back-up lights. 94
Old Nov 21, 2012 | 02:25 PM
Attachment 296545
i have the S1 Trans
and im guessing these are the leads
they are all greased up
ill clean them up and hopefully it will work
thanx for the help
Old Nov 21, 2012 | 07:59 PM
el crapitan's Avatar
thing about oil soaked wiring is that the insulation gets brittle and/weak. or chafes through or cracks easily, exposing the strands and causing a short. keeping that in mind with a brief visual inspection can sometimes help you find the problem quick.
just some food for thought i guess
egjake
10
Mar 30, 2009 01:18 PM
mr.bronx75
Oct 12, 2008 08:10 PM
importracegirl
Jun 9, 2007 07:29 PM
rocco
Jun 20, 2004 11:59 AM
AK94GSR
Jul 11, 2003 02:22 PM
