air temp sensor. help!!!!
Old Nov 20, 2012 | 11:09 AM
dc4b20's Avatar
Default air temp sensor. help!!!!
the car is a 93 hatchback with a d15b7. it has a problem with the idle. it surges up and down when it gets to operating temp. i am in the process of trying to locate that problem and i found a problem with the air temp sensor. i pulled the old one out and the prong that goes into the manifold was burnt and melted. so i replaced it with a new one and let the car idle and reach operating temp, idle problem was still there. so, i took the new air temp sensor out to inspect it and it was also burnt and melted. what could be causing this?
Old Nov 20, 2012 | 02:00 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: air temp sensor. help!!!!
post a pic of the sensor, for the surging idle check these:
-coolant level, if you are low you could have a leak causing air in the system making the idle up and down
-clean IACV (in the FAQs there is a write up)
-clean FITV (also a write up in the FAQ's)
Old Nov 20, 2012 | 05:10 PM
dc4b20's Avatar
fixed the jumpy idle. replaced the iacv with a used one and problem solved. i am gonna check the wiring for the temp sensor to see if that is the reason why it is burning up.
Old Nov 20, 2012 | 05:33 PM
a1320addict's Avatar
What wire colors do you have at your IAT and IACV connectors?
If you're IAT is getting burnt up, chances are you have the two switched, as they use the same style connector.
IACV - blue, yellow/black
IAT - red/yellow, green/black
Old Nov 21, 2012 | 05:58 AM
Technical Hero
Evap purge is also commonly swapped with IAT as well. I think the wire colors are yellow/black and red.
ls19integra95
Jan 15, 2008 02:01 PM
Kr4nG
Mar 13, 2007 11:01 AM
ericstambaugh07
Jan 20, 2007 01:52 AM
Ilove theDA
Sep 28, 2006 10:07 AM
