Catalytic converter light on?
Old Nov 20, 2012 | 04:48 AM
Jamesflo's Avatar
Default Catalytic converter light on?
Hey guys . So over the weekend my 97 jdm integra stalled while driving . I tired cranking it and such and still nothing . I then inspected everything and learned that I had no spark which meant to me changing my igniter. So I did that today and everything as back to normal and my car fired up and everything . However now the catalytic converter light came on and it has never before so does anything have any input? I was guess that because when the car was dead and I tried cranking it several times that is led to an excess of gas soo when I finally got it turned on it all burnt up and "tricked " the sensor to believe it was overheating ? By the way it's the stock cat and it's not te catalytic light on but the check engine . Thanks in advance
Old Nov 20, 2012 | 06:33 AM
cleansi's Avatar
Default Re: Catalytic converter light on?
https://honda-tech.com/forums/engine-management-tuning-124/2nd-year-same-problem-01-stock-gsr-dies-when-cold-3101859/
anything like this?
my dizzy was bad and made the car run rich (extra gas killed my oem cat)
now that your distributor is fixed your still gunna have to changed the cat have you pulled it off and looked at it ?
Old Nov 20, 2012 | 02:28 PM
Jamesflo's Avatar
No I haven't looked at it yet. Now do I have to change just the car or do I have to change the sensor in it as well?
Old Nov 21, 2012 | 04:42 AM
cleansi's Avatar
if your oxygen sensor is bad you would be receiving a specific code for p042 up or downstream.
if your cat is bad you should be receivig a code of Catalyst System Efficiency Below Threshold code.
hopefully its just clogged and you can pull it out and spray it out well with a can of brake cleaner but if its burnt up and the screens are destroyed that sucks.
if you need a new cat, OEM dealer replacements are $800.00 direct replacement systems like waker or dura last from vatozone are $350.00+ depending where you are
Khalfani
Aug 8, 2015 02:33 PM
flanker
Jun 22, 2008 11:12 AM
lance351
Aug 30, 2004 02:21 PM
ondafly
Mar 18, 2003 10:56 AM
Nelo_VTI 1.5 JDM
Dec 4, 2002 02:22 PM
