obd0 dpfi to mpfi obd0 turbo code 9
Old Nov 20, 2012 | 01:16 AM
dre33333's Avatar
Default obd0 dpfi to mpfi obd0 turbo code 9
have a code 9 need to kno what to do..have on car
450cc injectors
resistor box
tdo5 turbo
obd0 ecu
odb0 dizzy
bov
front mount intercooler
car starts step on gas and it sputters all most cuts out car was all good at first got like 5 miles and code came up car runs rough any ideas will help?
Old Nov 21, 2012 | 04:07 AM
dephtone's Avatar
Default Re: obd0 dpfi to mpfi obd0 turbo code 9
Code 9 is Cylinder Position Sensor. I would try a known good working distributor if you can borrow one from someone. If you can find the factory service manual, which I don't have offhand, they have troubleshooting steps for this code, checking wire resistances etc.
Old Nov 21, 2012 | 04:14 AM
blk_honda112's Avatar
Please make sure your cyp wires are not crossed . The computer is polarity sensitive . Wiring them backward can cause this error .
Old Nov 21, 2012 | 11:52 AM
dre33333's Avatar
got code 9 to go away thx my wires where crossed now one more question i have 450cc injectors can i run those with my stock ecu its a ps9 or whats the biggest injectors i can have on a stock ecu
Old Nov 21, 2012 | 08:10 PM
swordofdoom's Avatar
It depends if your still running on that injector resistor box.
Old Nov 22, 2012 | 02:42 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
You are boosting the stock ECU? What are you doing about the positive pressure reading off MAP and fuel?
Old Nov 22, 2012 | 05:17 AM
v4lu3s's Avatar
RTFM
the biggest ones you can run without problems are the stock injectors. with a stock ecu and bigger injectors you MAY run fine at higher rpm but will be way rich at low rpm and may not idle. you have a ps9...chip it and tune it with turboedit.
Torothebull
Jun 3, 2014 07:28 PM
builtsinglecam
Nov 15, 2009 02:05 AM
square_1
Apr 3, 2007 01:46 PM
SOHCEK-Turbo
Jul 21, 2004 11:49 AM
pj_baller00
Apr 16, 2004 08:07 AM
