BoostedBB6 Build Thread
Old Nov 19, 2012 | 04:29 PM
timoram's Avatar
Default BoostedBB6 Build Thread
Thought you buys may be interested in this build I'm doing.
It has taken some time to get it going but heres the basics.
February 2011
I picked up a 1998 Honda Prelude with a motor that was on its way out. I drove it around for some time and it seemed to drive fine so was in no rush to swap out the motor.
August 2011
My girlfriend was in need of a new car and we were out looking at Honda's and came across a black 99 with a GReddy turbo kit installed in her. Spoke with the seller but didn't plan on buying the car as it needed some work to make it road worthy.
we checked out some other cars and the more I looked at other Honda's the more I was interested in this black 5th gen.
I ended up txting the seller of the black 5th gen and asked him if he would be interested in a trade (my 5th gen for his 5th gen)....after a little talking we decided on a trade and I drove away in my 99 BB6.
I took this car to Mission one night and did 3 runs with the car. As expected it did nothing special due to huge wheels/no tune/bald tires and me being new to this car. Parked the car for a while to work on getting things together for the build I had in mind for her.
September 2011
I decided I would treat myself to a birthday gift of a 5 day permit on the car so I could drive her. On the 3rd day I was a little to brisk on the throttle and pushed her to hard and she let go.....cylinder #3's con rod decided to snap of just shy of the piston skirt and poke a hole in the back of the block....this was a poor way to go but put a rush on the build.
Fast forward to today. I have a new sleeved block in the works, fresh head, valves, cams, pistons, rods, and a bunch of machine work being done.
Here are some pictures of the current state of this project.
Day#1 When I brought her home. Very dirty, bad smoke smell in the ineterior, bad alternator, axle shafts were done, tires toast, needed oil change ect ect ect....but I washed her and waxed her up all nice.
Current state
shes a little dirty from all the junk from the trees here
engine bay shot
Snail shot!
Yes.....I know....It would be removed if it wasn't for the HUGE hols under this 747 wing that is bolted to the trunk lid...Need to find a new lid to put on here...thinking CF
Another of the engine bay.
Picking up the motor this weekend and will be getting her to the shop to tear is all down and get the show on the road!
The Engine
JDM H22A block
Darton ductile iron liner sleeves
Balanced crankshaft
SCAT H-beam rods
JE 9:1 Pistons 87.5mm bore
ACL bearings STD
The Head
JDM H22A head
O-ringed for high boost applications
She still needs some bits before shes ready to go but thats on the move!
The list of things to do seems endless but right now I plan on putting the block and head together with my power goal in mind (550whp). The current turbo setup can not flow anywhere near this kind of power but it will stay for the time being.
To Do
Vent valve cover with Jegs breather tank
Re-finish valve cover in crinkle red paint
AN fittings and braided lines between head and breather tank
Remove AC pump
Remove PS pump and loop the rack
Remove ABS pump and re-route lines
Switch to smaller washer bottle
Re-paint engine bay after seam welding/spot welding
Prep engine bay for 3inch charge piping
and a whole lot more
Will post pics up once the engine is being put together...550whp in 2012 is the goal...hoping to do this on boost alone but with hit the gas if need be!
Cleaned up the block and installed the KS Tuned Balance shaft deletion kit.
Removed a considerable amount of internal rotating mass from the motor with this as well and upped the oil pressure.
It is a little involved to install this in the motor as you need to remove the front lower case to remove the balance shafts as well as pull off the oil pan to access the oil passages you need to block.
Took about an hour and a half to do this but well worth it.
At the same time I replaced all the bottom end bearing and seals. Installed the Scat Pro Sport H-Beam con rods, JE 9:1 compression pistons and gapped all the rings accordingly.
Top end was hot tanked, did a nice valve job on the head, cleaned up all the intake and exhaust ports. Installed the Skunk 2 valves and lapped them in.
Next is to finish off the head with the rest of the Skunk 2 springs and such.
Pulled the oil pan to access the oiling ports for the balance shafts. Bit of stuff in the way.
#3 main off so I can tap and block the oil passage (its at the base of the larger hole visible in the bottom of the picture)
Bit better view of the hole I am tapping.
Front cover off to block the balance shaft openings.
KS Tuned Balance Shaft Delete plate and plugs installed on the front cover.
Here's the front of the block with the front cover removed. The two large holes are where the balance shafts use to run. These things were heavy and robbed some power....GONE I SAY!!
Front cover re-installed on the block. Removed some excess rotating mass and cleaned up the block.....still needs to be steam cleaned, now that the plugs are in its off to be cleaned and painted up.
Here is the o-ringed cylinder head after a nice bath having the Skunk 2 valves lapped into there freshly cut seats. This has to be the first time I have used a micrometer to measure seat width but should be worth it when the temps get high.
APR studs in the block and test fitting the head. Had to order some new dowels to position the HG on there and locate the block. Yes, the pistons have oil on them, the sleeves are steel so I did not want them to rust while we are building.....expecting a bit of smoke on start up haha....will have to get a video on start up.
That's it for now. Have some more parts on order so I can get the head complete and installed on the block. Hope to have that complete in 1-2 weeks time. Then its time to pull the old motor and clean up the engine bay for the new heart.....looking forward to this. Plan is to have the motor in there and running but Jan 1/2013....End of 2013 +700whp BECAUSE RACE CAR!!
Old Dec 7, 2012 | 10:29 AM
edd805's Avatar
Default Re: BoostedBB6 Build Thread
sweeeeeeeeet build my friend
triggermike11
May 10, 2011 10:11 PM
tashmo
Oct 28, 2010 06:11 AM
Happy Gilmore
Jan 2, 2009 08:37 AM
AU K20A2
Apr 26, 2004 06:34 AM
speedaccordinly
Mar 19, 2003 06:08 PM
