B18c1 98 Civic Hatch Wont Start
Old Nov 18, 2012 | 01:05 PM
boosted84.5's Avatar
Default B18c1 98 Civic Hatch Wont Start
So here's the run down... I have a B18c1 swapped 98 Civic Hatchback. It will start and run for maybe 2-3 seconds then die. It idles up and down smoothly before it dies. It is not displaying a CEL. If i pull the plugs they are soaked with fuel. I have spark at the plugs, i have great fuel pressure, i have checked the main relay, checked fuses, fuel pump kicks on, ignition switch is good, icm and coil are good, and i swapped two different distributors off of running cars. No dice.. im running out of options here. ive been trouble shooting and testing every thing i can think of. Im losing my mind here... Please help!
Also, i pulled the motor from my other car, 94 Civic Coupe, and i drove it every day with no issues. Ive also had a B18c in my 98 Hatchback before so the swap was smooth as butter. It was pnp pretty much. It has to be something stupid im overlooking.
I have searched for weeks before posting this, so please dont post on my thread telling me to use the search function... Thats where i have gotten most of testing ideas from.
Old Nov 21, 2012 | 03:01 PM
mikelusmc12's Avatar
Default Re: B18c1 98 Civic Hatch Wont Start
Have you checked timing?
Old Nov 21, 2012 | 03:04 PM
Also have you changed plugs? and can check your primary O2 to make sure it's not bad.
Old Nov 21, 2012 | 03:07 PM
oh and make sure your plug wires aren't backwards.
josepagina
Aug 2, 2013 10:44 AM
boostedb20z
Sep 4, 2007 01:05 PM
Mag00n
Apr 11, 2007 09:40 AM
