oil pressure gauge not reading anything
Old Nov 18, 2012 | 08:27 AM
frogg5872's Avatar
Default oil pressure gauge not reading anything
Its not even at 0.... When I was driving i noticed it was below the 0 line. Was a quart low ( pan gasket needs replaced). Filled and still showing nothing. All wiring clean and tight.
Is there a quick way to test it?
Old Nov 18, 2012 | 09:55 AM
el crapitan's Avatar
Default Re: oil pressure gauge not reading anything
try shorting the wire to ground. should peg the gauge. if it does, it's the sender.
if not, either the wring to the gauge or gauge itself is bad.
is the sender installed in the factory location?
LoseRPunKx182
Mar 22, 2006 04:26 AM
95LStizzy
Mar 12, 2006 12:35 PM
Si Shane
Oct 20, 2005 02:47 PM
AutoXsi2000
Jul 27, 2002 06:04 PM
Pengo
Jun 26, 2002 08:24 AM
