ebay oem type r oil & water pump
The USDM oil pump will fit on your JDM motor. The difference is the provision for the crank sensor. Also the lower timing belt cover is different on a JDM motor. So your JDM lower timing belt cover will not bolt onto the USDM oil pump. You will have to also buy a USDM lower cover or just buy a JDM oil pump and be done.
EGeezy
12
Dec 5, 2015 07:04 AM
