Exedy clutch or NAPA clutch?
Old Nov 18, 2012 | 05:42 AM
Brandon H.'s Avatar
Default Exedy clutch or NAPA clutch?
My clutch is starting to go in my 99 Si. Cruising around if I floor it the car revs up without touching the clutch.
I plan on getting a stock clutch. Either Exedy or NAPA. anyone have opinion on either. It's just a DD with a stock B16A2
Amazon Amazon
Old Nov 18, 2012 | 07:33 AM
jbpnoman's Avatar
Default Re: Exedy clutch or NAPA clutch?
Exedy, period. Don't forget to have your flywheel resurfaced as well.
Old Nov 18, 2012 | 08:29 AM
canadaek's Avatar
the last few napa clutch's i have installed where all stamped exedy (pressure plate and clutch disk not sure about the throw out bearing.
Old Nov 18, 2012 | 08:33 AM
NVturbo's Avatar
O.G. triple O.G.
Since you like to "floor it", I would get a better clutch than the one you're referring to.
Old Nov 18, 2012 | 08:47 AM
purgat0ry's Avatar
Exedy is a Daiken clutch; so far as I knew, Daiken made / makes quite a bit of honda OEM.
I may be incorrect though.
Old Nov 18, 2012 | 09:14 AM
Brandon H.'s Avatar
I was just giving an example that under load the friction disk is slipping on the flywheel. Like if floored, or going up a parking garage in 2nd gear if I tap the throttle it will spin. I have to careful on it until this upcoming weekend so I can change it, but I need to order one tonight. And hthe flywheel will be resurfaced or replaced depending on how bad it is.
I baby the car, it already has a very heavy clutch in it, I want to go back to stock.
anewfoundkevin
Jul 12, 2010 02:25 AM
SSJSubgeta
Oct 22, 2005 12:20 PM
xunkn0vvnx
Mar 9, 2005 01:47 AM
danny98r
Jun 24, 2004 12:15 PM
SIK IN DA HED
Sep 11, 2001 09:17 AM
