quick harness question, dpfi obd0 to mpfi obd1 vtec
Old Nov 17, 2012 | 07:40 PM
t-town_ep's Avatar
Default quick harness question, dpfi obd0 to mpfi obd1 vtec
I'm doing a d15b2/z6 mini me. Right now the car is still dpfi and obd0, I will be putting the head on sometime next week.
Should I use the std harness? Or the z6 harness? I want to know which one will be easiest for me.
Thanks,
Lee
Old Nov 17, 2012 | 09:00 PM
crx_si-r's Avatar
Default Re: quick harness question, dpfi obd0 to mpfi obd1 vtec
Never use the harness from the motor. Use the stock one for the car, and modify it to match the motor. I make plug n play harnesses if you need one. Check my sig below
Old Nov 18, 2012 | 08:42 AM
b20c's Avatar
yea bro you have to use the ef dx dpfi harness wired to mpfi and an obd1 jumper/dizzy/ecu/4-wire o2sensor. if u had to ask that qestion you should prob send off your dpfi harness to be made, or just buy one alrrady made unless your gonna run the setup dpfi which would suck and your ecu isnt vtec. u need to obd1 it with a p28 with your factory dpfi harness converted to mpfi/obd1 & obd1 jumper/dizzy/ecu/o2 i tried to make that simple bro
Old Nov 19, 2012 | 12:54 AM
crxdxmusbslo's Avatar
No, don't send off to be "made". I hate all the advertising on here. The wiring for obd0 dpfi to obd1 is simple with a jumper harness. There are many that already come with for female side of you 4 wire o2 for about a 1/3 of the price. Just google 0BD0 dpfi to OBD1 ecu jumper harness.
LakeSquad_ed3
Oct 17, 2014 10:40 AM
VegasEFHB
10
Oct 15, 2014 12:22 PM
John The G
10
Oct 22, 2010 06:44 PM
e12ikktos
Aug 26, 2009 03:00 PM
Honda_Fanatic
Oct 29, 2007 08:52 AM
