Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission bearing on it's way out?
Old Nov 17, 2012 | 04:44 PM
amej8's Avatar
Default Transmission bearing on it's way out?
Car is a 99 ex, stock motor/tranny, 231k miles.
Earlier today I was leaving from a store and out of no where, I was rolling in first and my transmission started to whine ridiculously loud. It made the sound you hear when you're in reverse...except I was going forward. It scared the **** out of me. No sound at idle / stopped. I had to stop at a red light right when it started but as I went again, it started. The higher the speed, the higher the pitch. It got quieter at higher speeds. It seemed to sound the worst in the first couple gears and happened even in neutral as long as I was rolling. About 10 minutes later, poof, it just stopped within a split second, while I was moving. The transmission sat for just over an hour after being warmed up all the way, so it wasn't completely cold but pretty cool at that point.
Any ideas on what it could be? I know my input shaft bearing has been on it's way out for many years because when I push in / let out my clutch I can hear a slapping / grinding noise that comes and goes away (goes away with the clutch in).
Old Nov 17, 2012 | 07:56 PM
160hpz6na's Avatar
Default Re: Transmission bearing on it's way out?
It is definitely your input shaft bearing. The noise you hear when you push in your clutch is the throw-out bearing. A new ISB will only run you about 30 dollars.
Old Nov 18, 2012 | 01:57 AM
jbpnoman's Avatar
The part he doesn't mention is that it is labor intensive as a ************ to replace. An experienced person can do it in about 4-6 hours, and will charge you $300-$1000. If you've never ripped apart a transmission before, you can get all of the necessary tools for less than $30. FSMs detail the procedure, and can be found online fairly easily. No, the Haynes/Chilton/Bentley books don't detail it. While you're in there, you might as well replace all of your bearings, seals, and synchros. The full kit from www.synchrotech-transmissions.com will run you about $130, IIRC. Better to do it all together now, than have to do it again in the near future when other bearings or synchros wear out.
Old Nov 18, 2012 | 10:33 AM
amej8's Avatar
Is it okay to drive it still? lol.
I think I'll just get a different transmission. I don't have the kind of money to pay for labor and parts for a transmission fix unfortunately.
Lasty K
May 5, 2018 02:32 PM
amej8
Nov 19, 2012 08:36 AM
lowbudget88si
Mar 10, 2005 12:31 PM
Drew96EJ
Sep 23, 2003 10:09 AM
MikeMAN
Jun 30, 2003 06:27 PM
