Can someone identify this sensor? 1998 Accord
Old Nov 17, 2012 | 11:25 AM
SnoopyMan's Avatar
Icon2 Can someone identify this sensor? 1998 Accord
Hello,
While pulling an F23A1 engine from my '98' accord I broke a sensor. It sits just beneath the Distributor and between another sensor and a coolant inlet. I looked in the Service Manual, but I can't find any section or parts list that indicates what this part is. Searching through google the nearest or best explanation I could find was it is a coolant temp sensor, one of two ( they indicated that both sensors were for coolant temp).
I am including the following photo.
Any help is greatly appreciated.
SnoopyMan
Old Nov 17, 2012 | 11:47 AM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Can someone identify this sensor? 1998 Accord
ECT
Old Nov 21, 2012 | 07:43 PM
SnoopyMan's Avatar
Vegas,
Thanks. After you supplied the name I was able to then find it in the service manual. It was under PGM-FI System, component location index.
Also, most places were charging over $110 for the part, but I found one from www.chandlermotorsports.com for $9 + Shipping. Seems awfully cheap... the old adage, "you get what you pay for" scares me. I also thought about epoxying the plastic part back onto the metal bolt, as the plastic is what broke... but not too sure this would work. It's supposed to be a microphone that listens to the engine for frequency harmonics and allows the ECM to make corrections.
Again, thanks for you help.
SnoopyMan.
Old Nov 21, 2012 | 08:42 PM
GhostAccord's Avatar
SnoopyMan.
Actually it is a thermistor type sensor. AKA the engine coolant temp (ECT) sensor. Get one at a local JY for a couple bucks or new for $30. I think the microphone type sensor that you are talking about is the KS or knock sensor. Not the same thing.
You were correct with your original description. The 2 wire sensor is the engine coolant temp sensor that the engine control unit/computer uses and the single wire sensor is the ECT sensor that goes directly to the dash cluster for the temp gauge.
Old Dec 6, 2012 | 07:59 AM
SnoopyMan's Avatar
I confused this post. I actually broke both. I the ECT I broke from the start trying to stick a socket on it to see if it would come off. I allowed the wrench to tilt one way, which wrenched the tip right off. And, I also broke the knock sensor while trying to undo a brace on the back side of the engine. The plastic housing or cover broke off, but the sensor itself still looks good. I bought a new one for the $9. I still need to get the ECT; I will look to a local JY. Thanks for the tip!
Snoopy,
RicedOutVtec
May 1, 2017 02:19 PM
cfiiman
Mar 26, 2014 08:20 AM
Babong
17
Sep 20, 2011 08:35 AM
doitmyself2010
11
Jun 26, 2011 12:55 PM
