my bseries part out, hasport full race asr skunk2 cp pistons eagle rods plm toda reps
PLM Toda Replica brand new never used headers 350
Skunk2 Adjustable b series cam gears in silver 125
Skunk2 Adjustable b series cam gears in silver 120
Hasport EFB2 mounts for hydro transmission comes with post mount and rear bracket 450
Hasport Ef/Crx Linkage 120
84mm Cp pistons 12.5 Compression and ls/b20 eagle rods BNIB 750
b20z block with crank, windage tray oil pick up, rear main seal, oil pan, coolant tube with thermostat housing 250obo
Full-Race ProStreet Honda EF/ED Radiator Brand new! no fluids been ran through it 300
ASR 32mm Racing Hollow Swaybar Kit 88-91 Civc / CRX Brand new never used 450
skunk2 manifold gsr 180
70mm skunk2 alpha series throttle body 100
skunk2 manifold b16 180
type r manifold 100
70mm skunk2 billet throttle body 180
obd1 gsr bare block with golden eagle block gaurd, comes with matching main caps and girdle and its bolts nothing else is included 200FIRM
92-95 Civic Optional console what you see is what you get since its all i have of it..and the ends will need to be repaired notice the cracks in the picture 120
Aerocatch Hoodpins Plus Flush Locking Kit 100
DC/EG 3 post Hasport Driver side mount has minor tear 80
DC/EG Hasport Rear mount 80
90-91 Civic CRX EF SI engine wiring harness that was reworked to put in a obd2 gsr add vtec plugs, knock sensor plug, 4 wire o2 plugs (obd2 injector plugs no resistor, obd2 dizzy plug, obd2 alternator plug) also obd0-obd1 rywire jumper harness one pin is broken but no check engine came on or anything 350
could get more pics on my phone so please text me at 7816062829 ill respond back ASAP
type r manifold 100
Beto_619
May 23, 2016 07:29 PM
96Dc2 GSR
Dec 24, 2012 09:45 PM
ef9_frosty
Nov 7, 2009 02:24 AM
ohsheetadrian
Jun 2, 2008 03:49 PM
