supertech valve springs for f22a6
Old Nov 16, 2012 | 05:08 PM
ivan93egreppin210's Avatar
Default supertech valve springs for f22a6
Is anybody running them and what kind of camshaft do you have.
Old Nov 17, 2012 | 11:44 AM
Default Re: supertech valve springs for f22a6
So what valve springs you guys using if no ones running these?
Old Nov 17, 2012 | 12:26 PM
GhostAccord's Avatar
I ran a set of stock yellow/green (int.) & pink (exh.) springs from a 96-97 F22B6 Odyssey with my F22parts stage 2 cam. No issues for 10k miles running to 6500-7000 rpm.
I will be running a set of stock A6 springs with my custom camshaft on my current build. Cam doesn't have much more lift than the A6, however it does have longer duration.
Old Nov 18, 2012 | 08:26 PM
A few tuners have said that my setup runs out of spring at 6.7 k were I make max power of 194hp. That on a delta 272 and f22a6 springs. I'm going to buy the supertech regardless. Just wanted to see who was running them.
Old Nov 19, 2012 | 04:23 PM
What do they mean by it runs out of spring? Not enough seat pressure and they start to float.
6.7 k RPM?
I have a set of KMS springs and retainers that claim to be good up to 10k with a seat pressure of 75 psi.
phelpsj2
Jul 18, 2010 10:34 AM
Jdmb16sir2
15
Oct 22, 2007 01:11 PM
JdM_Eg_6
Mar 22, 2004 04:48 PM
tek_civic
Jul 7, 2003 10:51 AM
Casey
10
Jan 27, 2003 05:01 PM
