car won't start, radio turns off when i turn on the headlights
Old Nov 16, 2012 | 04:40 PM
poptik's Avatar
Default car won't start, radio turns off when i turn on the headlights
So my car won't start, the battery was replaced about 4 months ago, can it be a bad alternator?
this is a 1994 Acura Integra LS
Old Nov 17, 2012 | 10:14 AM
poptik's Avatar
Default Re: car won't start, radio turns off when i turn on the headlights
i'm guessing battery lol
Old Nov 17, 2012 | 12:10 PM
fcm's Avatar
fcm
Old Fart
Check your main grounds, when one circuit, [in your case head lights] has an effect on another unrelated circuit, [radio] it is almost always due to a grounding problem, check your main grounds first, batt. post and cable clamp, batt. to chassis and chassis to engine ground, DO NOT just eyeball the connections, disconnect/clean/reconnect.
FYI, most batt./alt. shops will do batt./alt./charging system checks for free, it only takes a few min., but do the grounds first, check your local Interstate Batteries store. 94
Old Nov 20, 2012 | 11:57 AM
poptik's Avatar
ok it's the battery completely drained, but i got someone to jump start it now it sputters like crazy, if i go past ~3K rpm it sputters and wont accelerate
is this due to the alternator not being charged? problems problems problems
Old Nov 20, 2012 | 01:59 PM
chingbao's Avatar
bad ground?
Old Nov 20, 2012 | 03:18 PM
fcm's Avatar
fcm
Old Fart
An alt. does not get charged, "is this due to the alternator not being charged", it charges, [or does not charge], a batt. will or will not get charged.
Have you checked/redone thje main grounds? 94
Old Nov 20, 2012 | 03:30 PM
poptik's Avatar
I just sold the car as is.
Old Nov 21, 2012 | 05:44 AM
fcm's Avatar
fcm
Old Fart
I guess that's one way to solve a problem. 94
Old Nov 22, 2012 | 01:08 PM
poptik's Avatar
lol tired of problems with it, getting a new car with warranty, no more worries lol
r4in
Jan 3, 2014 09:27 AM
sunshine5882
Jan 18, 2013 01:15 PM
patrickstar
12
Jan 12, 2009 05:22 PM
AzntstyleZ
10
Feb 27, 2004 10:50 PM
dumbchild
Sep 3, 2002 03:25 PM
