Tire width question
Old Nov 16, 2012 | 02:46 PM
Brandon25's Avatar
Default Tire width question
hey, i'm shopping for a set of tires/rims for a 92 accord lx, what is the widest set possible for it? looking for some rota slipstreams, not sure what tires to get. I'm a bit of a noob so can anyone point me in the right direction for sizes? thanks!
Old Nov 16, 2012 | 10:15 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Tire width question
Do you have a diameter in mind?
I would not go any larger than 17" with diameter, and 7.5" is always the width I've seen for 17" for the CB/CDs. IIRC using a 42-45mm offset.
It also would be helpful to state which body style your LX is. A coupe may have different rear wheel housing dimensions from a Sedan or Wagon.
Old Nov 17, 2012 | 02:07 AM
aristides's Avatar
Widest I'd go would be 8inch
Old Nov 19, 2012 | 03:33 PM
Brandon25's Avatar
mine's a coupe, I found a set of 15 in. slips on tires on kijiji, not sure if I'm better off buying brand new with a bigger size or used :S
Old Nov 19, 2012 | 08:15 PM
J...H22's Avatar
Interested in rolling the fenders, or stretching the tires? If so then you could go fairly wide, if that's the look you're going for. Just keep in mind the offset, and undue stress on the axles,wheel bearings,and suspension parts as well.
hondajeff
Jan 29, 2007 11:16 AM
Mr. Vapor
Dec 29, 2006 06:37 AM
leoverte
Apr 14, 2006 10:36 PM
rgoins
Mar 23, 2006 02:03 PM
msedacca
Feb 4, 2006 12:48 PM
