B-series crank sensor wiring question
Old Nov 16, 2012 | 02:36 PM
CW-ITR's Avatar
Icon2 B-series crank sensor wiring question
Hi guys, I need to know where these two wires from my crank sensor attach to the OBD0-OBD2a jumper harness (Boomslang if that matter).
Additional info:
_JDM ITR swap into '89 CRX Si with USDM B-series oil pump and crank sensor.
_OBD0-OBD2a Boomslang jumper harness.
_USDM ITR OBD2a ECU.
Thanks,
Old Nov 16, 2012 | 02:41 PM
sirekhatch's Avatar
Default Re: B-series crank sensor wiring question
If i'm not mistaken ( someone correct me if i'm wrong..) you will not have a crank sensor located on the oil pump on a jdm motor.. Of course your ecu ( usdm ) will look for one, but jdm motors crank sensor is ran through the distributor.
Old Nov 16, 2012 | 04:25 PM
CW-ITR's Avatar
You are technically correct. But, I installed an USDM B-series oil pump and a crank sensor for ca B.A.R.
Old Nov 16, 2012 | 05:25 PM
crx_si-r's Avatar
your referring to the CKF (Crank Flutctuation) sensor found on 96+ civic/integras right. that being the case. if you have the factory connector your will be wiring up a 2 pin gray connector
1st wire - blue with red stripe
2nd wire - white with red stripe
looking at the back of the plug (wire side facing you):
(blue/red)(white/red)
blue/red goes to C1
white/red goes to C11
hope that makes sense
Old Nov 19, 2012 | 06:03 PM
CW-ITR's Avatar
blue/red goes to C1
Thanks "crx_si". I forgot that you build harnesses. The two wires came straight out off the CKF and there is an OBD0-OBD2a jumper harness conecting to the USDM ITR OBD2a ECU. with that said where do thse two CKF wires connect to? Thanks
Old Nov 19, 2012 | 06:14 PM
crx_si-r's Avatar
no problem. those wires go to the ckf sensor located by the oil pump.
feel free to txt me, i can send you pics of the connector (i have a few obd2 b-series harnesses lying around) or message me on FB (link below)
916-541-5266
roycivic92
Feb 5, 2012 09:33 PM
2kgs-R
Mar 6, 2007 08:36 AM
The Jamaican
Apr 14, 2003 09:09 AM
