FS: 2000 FBP Integra Type R #135 South Jersey Region
1 owner - me
Asking $8,500
Car chassis has 260,600 miles on it and engine block has 80,000 miles since last rebuild.
New head as of Nov 11, 2012.
Bottom end should be good for another 100,000+ miles.
Brakes and rotors were changed recently (Original ones lasted almost 12 years with mostly highway miles)
Garage kept minimal rust. Exhaust still in excellent shape (barely any rust)
The good
Compression numbers (psi) #1 250 #2 250 #3 242 #4 245
New engine head
No CEL
Inspection sticker till December 2013. It will pass inspection as is.
Garage kept! Minimal rust on exhaust and all other parts.
You don't have to do much when you get the car. Mostly maintenance.
Has air conditioning for those hot days! No leaks!!
1 owner
Interior is in excellent condition.
The Bad
Body has some small dings. You can find them if you look for them, but for the most part you don’t notice them.
1 accident driver side front fender. Full repaired in 2000. Car drives straight. CarFax shows that airbag was deployed, but that is absolutely not true. Their facts are wrong.
New parts just installed:
Brand new OEM head installed (came with new Cams/Valves/Rocker Arms)
Head gasket
Intake gasket
Exhaust gasket
Spark Plugs
NGK Wires
Tensioner
OEM Engine Block plug
Distributor Cap/Rotor
Timing belt
Water pump
Fuel Filter
Fuel Injectors cleaned by Injector Rehab
Brand new crank pulley and bolt
Engine internals:
Wiseco K542M815 9.7:1 – 10.2:1 Piston Kit
Eagle CRS5430A3D H Beam Rods
Golden Eagle MFG Oil Squirter Plugs
ACL Main Bearings
ACL Rod Bearings
More parts:
Competition Clutch 8026-1620 6-Puck Sprung, Ceramic
Speed Bleeders (for changing brake fluid, makes bleeding and changing brake fluid an EASY 1 man job)
Comptech Icebox and Short Intake
Mugen 4-2-1 USDM header
Random Technology Hi-Flow Ceramic Catalytic Converter
Mugen Twinloop catback exhaust
Mugen Lowdowns
Mugen Rear Sway Bar
15x7 Wheels + Bridgestone Pontenza RE11 205/50 R15 (NEW Summer only)
HardRace Front and Rear Camber Kit
Hasport DCSTK, 62a Durometer engine mounts (driver side and rear mount)
Deleted Power Doorlock buttons (RS Handles)
Deleted Rear Wiper
JDM Honda Access Pedal Covers
AEM Digital Gauges Water Temp and Oil Pressure (AEM 30-4407)
Koyo Drain Bolt Set (magnetic bolts for oil pan and transmission)
JVC Double DIN Head Unit
Hella Supertone Horns
Car Alarm
Car is in South Jersey. Daily driver, 90% highway miles.
PM me - no trades - just cash.
Reason for selling: I bought a new car and can't afford the insurance to keep the R.
More photos here: http://salsa-dancing-addict.com/ITRForSale
Asking $8,500
The good
New engine head
No CEL
1 owner
The Bad
Head gasket
Intake gasket
Exhaust gasket
Spark Plugs
NGK Wires
Tensioner
Timing belt
Water pump
Fuel Filter
Engine internals:
ACL Main Bearings
ACL Rod Bearings
More parts:
Mugen Lowdowns
Mugen Rear Sway Bar
Deleted Rear Wiper
Car Alarm
REDTMNT
Jul 12, 2009 07:58 PM
400WHPITR
Feb 26, 2006 11:13 AM
MinorityGreg
Aug 13, 2005 11:08 AM
