Going from f22b2 to f22a6
Old Nov 16, 2012 | 07:29 AM
estepaul93's Avatar
Default Going from f22b2 to f22a6
Hi
I have a 96 accord I need some help want to know what I need swapping out m y f22b2 puting in f22a6 can I use the same Tranny do I need to change the ecu will it drop in need some Guidance
Old Nov 16, 2012 | 03:46 PM
kd97accord's Avatar
Default Re: Going from f22b2 to f22a6
not sure on the ecu part, but the tranny will bolt right up, i know this because i used a f22a1 gearbox on my f22b2 and all the bolts line up
Old Nov 17, 2012 | 12:46 AM
holmesnmanny's Avatar
If you're in CA it won't pass smog. I'm going to assume you're not in CA.
You will need an obd2 to obd1 conversion harness. Also, you will need to swap pins A11 and A6 before the harness and grab a distributor for the f22A6 and an ecu for the f22A6. Also, you will need to get an IAB kit for the f22a6 motor and wire it in. I think rywire sells em. Also, you will need a conversion kit for the distributor plugs, I think rywire sells this too. The crank sensor for your existing harness is at the oil pump.
Old Nov 17, 2012 | 04:55 AM
estepaul93's Avatar
I have dizzy the Harness for the a6 can just swap intakes
Intakes for the meantime
Old Nov 18, 2012 | 09:53 AM
dglassmyer's Avatar
Just curious but what is the purpose of this swap?
The A6 does have some very mild benefit over the B2, if your end goal is power, there are much better options to choose from.
Old Nov 18, 2012 | 10:42 AM
estepaul93's Avatar
I just need the car to drive got good deal Complete engine with Trans 200 bucks
Old Nov 18, 2012 | 10:51 AM
estepaul93's Avatar
One of the harness plugs that run to the plugs That run back into the car are different It's black with yellow stripe and the other ones black with white stripe The one from the engine harness has three The engine harness has five and and plug only has two Plugs are different
Old Nov 18, 2012 | 09:16 PM
can u take a picture
Old Nov 19, 2012 | 06:11 AM
estepaul93's Avatar
Ok I post the pic of the Harness its in my Album
Old Nov 20, 2012 | 08:06 AM
estepaul93's Avatar
How do I make the engine harness from engine at f22a6 work in my
96 Accord
Old Nov 21, 2012 | 02:56 AM
Instead of swapping harnesses, it might be best to just cut what you need from the donor harness and buy some heat shrink type of connectors and just splice it in, imo. The only thing you will need to add if you choose to keep using your existing harness is the iab wire and connector. The f22a6 motor uses iab's.
However, if the shock tower connectors you have from both harnesses are plug n play, you can choose to swap out the harnesses. Just remember that you will need to swap pins A6 and A11.
Old Nov 21, 2012 | 03:45 AM
estepaul93's Avatar
How do u do that i never Messed with harnesses so I still have to chage ecu what other ecu can I use
Old Nov 21, 2012 | 03:52 AM
estepaul93's Avatar
Old Nov 27, 2012 | 07:47 AM
estepaul93's Avatar
Will pt6 ecu that's Auto work a in a 5 speed
Vamikeymike
Apr 15, 2013 10:04 PM
sir.rexington
15
Oct 20, 2010 01:48 PM
MurtazaDSM
Nov 3, 2009 03:48 PM
avaldez
Jun 24, 2009 12:59 PM
BB6-213
Jun 22, 2004 12:01 AM
