help all motor gsr
Old Nov 15, 2012 | 09:02 PM
gsr-ek-hatch's Avatar
Icon2 help all motor gsr
i need some help i have a 96 gsr long block im trying to see what pistons should i get for my set up i would like to get somewhere around 200 to 215hp what i have is a stuck gsr head no port and polish or anything with:
ferrea valve train
skunk2 stage 2 tuner series cams
skunk2 cam gears
skunk2 intake mani with a 70mm tb
Block is 81.5mm bore
micropolish crank
arp main studs
type r oil and water pump
i was going to put 12:5:1 cp pistons with eagle rods with a hondata s300 but im not sure if this is going to take me to my goal any advice will be really good thanks
Old Nov 15, 2012 | 09:19 PM
mark@silbernage's Avatar
Default Re: help all motor gsr
What helps narrow things down is to filter that list down to the items which alter power output, eliminating the reliability items. This leaves increased compression (pistons), intake w/70mm tb, and S2T2 cam. I think the tb is a bit large for the rest of the build (so far), btw.
In terms of your goal: I'm guessing but would lean towards 'almost', perhaps not quite. If you have a very good tuner it'll be close.
Next big increase, if you stick with N/A, are head P&P, good exhaust, and consider S2 pro or DD Tech cams. (not in any particular order)
If you go very far past 200HP pay attention to the duty cycle on your injectors.
Mark
Old Nov 16, 2012 | 08:08 AM
accorse07's Avatar
If you follow through with the 12.5:1 pistons and change from tuner to pro cams...that 200hp goal should be a cinch with an s300.
Old Nov 17, 2012 | 08:57 AM
You guys mean skunk2 stage 2 pro series
cyrus_gremlins
Aug 9, 2010 11:55 PM
phoshyzzle
Jan 29, 2009 04:26 PM
sirt8669
Mar 23, 2008 10:54 AM
methodz55
May 13, 2005 05:11 AM
boost fiend
Oct 5, 2003 07:40 PM
