Oil on my spark plugs?
Old Oct 18, 2002 | 01:23 PM
elpermgrande's Avatar
Default Oil on my spark plugs?
I was changing my plugs today and when I pulled out my 2,3,4 plugs they were dripping oil.I did a search and almost everybody said it was the grommets in the valve cover then some said it was the rings.I have an LS engine and I wasn't sure because I replaced my valve cover gasket and the seals not too long ago.
Old Oct 18, 2002 | 01:29 PM
Fishcat37's Avatar
Default Re: Oil on my spark plugs? (elpermgrande)
Most likely it's those 4 rubber grommets that go on top of the spark plug holes on the bottom of the valve cover. Clean out all of the oil, and replace all 4 grommets w/ brand new ones, and torque your valve cover down to spec. That will most likely fix it.........if it doesn't.....then im not sure
Old Oct 18, 2002 | 02:51 PM
kikujiro's Avatar
Dripping in oil??? Sounds like you're in trouble!
Old Oct 18, 2002 | 03:12 PM
unabonger's Avatar
Default Re: Oil on my spark plugs? (kikujiro)
Try changing your valve seals.
Old Oct 18, 2002 | 03:15 PM
Magick211's Avatar
Default Re: Oil on my spark plugs? (unabonger)
The sparkplug o-rings on the valve cover may be bad, mine were so i used some gasket sealer underneath them worked for now but im gonna buy some new ones soon. I also have a ls.
Old Oct 18, 2002 | 04:04 PM
MrTodd's Avatar
Default Re: Oil on my spark plugs? (CivicBoyZC)
If your piston rings were bad it mostly likely wouldn't be dripping oil - also your exhaust would be pumping out a ton of smoke.
It wouldn't hurt replacing the plugs after you replace the seals (add some ultra black gasket maker to create a better seal)
Old Oct 18, 2002 | 04:42 PM
Shea-bird's Avatar
New User
what he said...
collkid
May 12, 2017 11:39 AM
BlueRex1020
Feb 8, 2007 09:17 PM
froger
Feb 3, 2005 12:39 PM
lke2drvgsr
Sep 29, 2003 07:25 PM
chromedome
Mar 11, 2002 09:00 PM
