Sqeauking noise coming from rear driver side suspension
Old Nov 14, 2012 | 09:53 PM
mouab18c1's Avatar
Default Sqeauking noise coming from rear driver side suspension
My car is making this stupid annoying *** sound from my driver side rear suspension. It squeaks even when just driving on a smooth road. I replaced the rear sway bar bushings since that was the case before but now it didn't make any difference. Any ideas?
Old Nov 15, 2012 | 02:54 AM
JuicedUpRice's Avatar
Default Re: Sqeauking noise coming from rear driver side suspension
lol my brother's integra is doing the same thing.does it kinda sound like a rubber ducky or a seagull?
we have been investigating it for a while now..cant figure it out.
Old Nov 15, 2012 | 04:52 AM
NODAKDCteg's Avatar
replace ALL your bushings? just the sway bar wont fix it. Also what is your suspension set up? Coilovers, Lowering Springs? Stock Springs?
Old Nov 15, 2012 | 08:14 AM
mouab18c1's Avatar
Nope don't sound like that. Just sounds like a bed rocking squeak
Old Nov 15, 2012 | 08:17 AM
mouab18c1's Avatar
Tokico Illuminas with ground control coilovers.
Old Nov 15, 2012 | 09:46 AM
TunerN00b's Avatar
Check the spring isolators. GC upper spring perches include polyurethane ones, which can squeak.
Aside from that, poly swaybar chassis bushings can make noise (so do spherical endlinks, but most people shouldn't run those on the street). My swaybar is wrapped in teflon under the bushings to help prevent noise.
Old Nov 15, 2012 | 11:25 AM
mouab18c1's Avatar
The isolator is what I was thinking about. It did not squeak when it was sitting on springs. This all started after I installed the ground controls
katsareus
Jun 19, 2006 04:42 AM
...Baker
Suspension & Brakes
Jun 10, 2006 09:30 AM
idriveadelsol7
Suspension & Brakes
Aug 9, 2005 10:36 AM
SYDNEYSIDER
Mar 26, 2002 06:05 PM
