How many CC's lowered when head is milled
Old Nov 14, 2012 | 09:23 PM
EsotericImage's Avatar
Retired Moderator
Default How many CC's lowered when head is milled
Ive searched everywhere but all i can find is specs for chevys, fords and mopars..
Once the head is milled, the CC's in combustion chamber are lowered.. So my question is what is the ratio?
I saw on the domestics boards that with their larger chambers theyre ratio is 1cc per .005 milled. 78-84cc for those guys.
Now our CC's are close to half of that..So ours would be close to 1cc per .010
anyone have any real information or maybe a link.
Our search function brings up any and every thread with CC, milled and nothing with solid info
Old Nov 14, 2012 | 09:48 PM
mark@silbernage's Avatar
Default Re: How many CC's lowered when head is milled
Formula for volume (V) = pi * r(2) * h, so V / pi * r(2) = h
Stock cyl size is 81.5mm, or 8.15cm, and 1/2 of that (radius) is 4.075cm
3.14159 * 4.075 * 4.075 = 52.168, so h = 1 / 52.168, or .0191cm
So, a 1cc slice of the cylinder that is 81.5mm across is .0191cm, 0.191mm
Or .00748 inch
Since the head has quench areas, it's not a perfect cylinder, so I'd expect that figure to need to be increased from 7.5 thousandths to really reduce the volume by 1cc.
So - your figure of 10 thousandths sounds pretty good.
Old Nov 15, 2012 | 09:35 AM
spAdam's Avatar
Loved
Community Favorite
You're on a p8r iirc, you should be able to take .010 off no problem without getting into the quench areas. So yeah, the above seems about right. B20 maths:
84mm bore: pi/4*d^2*h = (~)3.14159/4*84^2*.010*25.4 = 1407mm^3 = 1.407cc
84.5mm bore: 3.14159/4*84.5^2*.010*25.4 = 1424mm^3 = 1.424cc
Old Nov 15, 2012 | 12:16 PM
You'll want to be sure that the distance from the piston to the quench areas remains at least 30 thousandths, ideally 40, from what I've read.
The stretch of rod bolts means that at high RPM, the piston will move closer to the head, requiring a buffer space to avoid hitting the head (also reduces piston to valve clearances).
The P2V is more of an issue with higher cam lifts (aftermarket) and altered timing.
egycasper
Jan 3, 2017 12:07 AM
Chino Chaplin
Apr 30, 2015 04:44 PM
dayaftertomorrow
21
Mar 7, 2006 11:39 AM
BryanPendleton
May 7, 2004 08:19 AM
