88 crx Limp mode
Old Nov 14, 2012 | 06:33 PM
crxriced's Avatar
Default 88 crx Limp mode
I have an 88 crx si with a OBD0 dohc zc. I am running the stock Ecu and no matter how hard i try the car will not exceed 2500 rpms. Its like it hits a rev limiter. I am running the stock si ecu and went to check for any codes and i couldnt believe it. Me and 5 others are counting 11 blinks. There is no code 11. Any ideas
Old Nov 14, 2012 | 07:46 PM
90civic1.5's Avatar
Default Re: 88 crx Limp mode
bad PCM?
Old Nov 14, 2012 | 08:16 PM
crxriced's Avatar
Originally Posted by 90civic1.5
bad PCM?
I want to say maybe but if it was bad would the car run at all
Old Nov 14, 2012 | 08:39 PM
90civic1.5's Avatar
a car can still run a on bad ecu. you should try and swap out for a good known ecu and check it.
yeah if you got a code 11 it would be 1 solid flash for a sec then 1 quick flash after that.
Old Nov 15, 2012 | 09:17 AM
crxriced's Avatar
Yeah i figured that. Went and checked the blinks again today and 11 fast blinks. Ill see if i can find another ecu tomorrow
Old Nov 19, 2012 | 04:37 PM
90civic1.5's Avatar
Get another ecu yet?
Old Nov 19, 2012 | 04:59 PM
crxriced's Avatar
Not yet. Had to order one. No one near me had 1
cklauj207
Oct 18, 2012 05:25 AM
rocketrex
Jul 3, 2007 06:29 PM
mkinpwrat12g's
Sep 14, 2005 05:50 AM
4gvtec
12
Sep 15, 2002 10:47 AM
Type R
Dec 12, 2001 08:43 PM
