MY 90 Dx Project-baby steps
Old Nov 14, 2012 | 03:38 PM
winquest1000's Avatar
Default MY 90 Dx Project-baby steps
hey guys long time reader, figured id start my own thread to keep you guys entertained, plus could use some input from time time
info:
Bought car in august what it had
d15b2 with 320000
cracked windsheild minimal rust as it was an alberta car
came with tons of extra parts and wheels and hood
Whats happened/ dont to it
Engine blew-may have been a coolant hose was kinked
so bought a rough si with a d16a6 that had only 82000kms on it
swapped it into dx kept dx tranny for now (ran out of time)
stripped the si for parts!
did the MPFI Swap had issues doing it but it worked out
Rad started steaming a week after swap, decided to thermostat and water pumper
-waterpump bolt snapped off, took two weeks of bad weather and trying to drill it out to decide to sand bolt down and use three bolts and Permatek ( it worked)
also had a sticky pedal
- cleaned the throttle body and lubed throttle cable and adjusted it all good now
put on one of the si doors as my window was off track and would go back in-may be the regulator
car is running 9.5 out of 10
---- only thing is when i let off of gas it feels a little rough may be 02 sensor
Future mods planed
- touch up body
-Paint job
-Wire tuck/ clean up wires
-SI tranny swap
-Bigger rad
-Lower rad
-Have an newish cat and piping will put that in
IF anyone has any recommendations on what i should do let me know
--------------Will post pics soon----------
Old Nov 15, 2012 | 05:27 AM
Default Re: MY 90 Dx Project-baby steps
Hey guys an issues just poped up
Cars running good but just found an oil leak i though it was coming from the oil pan gasket on the driver side but when i used talc powder i found that it wasnt the case
it seems to be leaking from driver side corner where oil pan meats the engine above their where the timing cover corner meats up with the engine
do you guys have any ideas on what it could be
Old Nov 15, 2012 | 07:49 PM
DumpdEJ6's Avatar
I like the tuna here
Crank seal maybe? I'd pull the timing belt cover off to check. You don't want oil getting on the belt, it will prematurely wear it out.
Old Nov 18, 2012 | 08:12 PM
so havent had a chance to do it yet however another issue popped up that i had hoped would happen i had changed out my wateropump snapped the bolt off and couldnt drill it out soo used gasket sealer on it it worked, however now where the oils leaking its leaking coolant so im pretty sure thats the waterpump im going to try to get the c over off tommorow if its the the crank seal fo the oil and the waterpump is leaking is their any bandaids that i could use ? any sealants? just to get through winter
Old Nov 18, 2012 | 09:53 PM
jonGSR's Avatar
An easy fix is just replacing the camshaft seal and front main seal at the same time. You said you changed the water pump, then you must have removed the crank pulley and all of the plastic covers. Having those items removed it would only take another 30 mins tops to get both of those seals changed. Do it right now, save yourself the headache.
Ed7si
16
Feb 27, 2013 06:18 PM
winquest1000
Nov 12, 2012 09:42 AM
DragonHawk
Feb 4, 2012 10:08 PM
Canadian_EF
Jul 11, 2009 01:14 PM
Vinceg99
11
Sep 25, 2003 06:12 PM
