89 crx possible grounding issue
Old Nov 14, 2012 | 02:22 PM
93dabeast's Avatar
Default 89 crx possible grounding issue
i just picked up an 89 crx that is in ok shape considering it had been painted flat purple by the previous owner. i have a few concerns. the gas guage reads full all the time and when i park it for a lil while it will go down to almost empty (which might be the actual amount of gas) and once i start it it goes to full, the battery light is on but i tested the alternator and it is putting out over 13.5 volts, the parking lights turn on when you turn the car on.
Is it a bad ground? i checked the grounds in the engine bay and they all seem fine. where else should i look? the car is mostly stock aside from an aftermarket headunit and rear speakers. any help will be appreciated.
Old Nov 15, 2012 | 09:50 AM
93dabeast's Avatar
Default Re: 89 crx possible grounding issue
Anyone?
Old Nov 18, 2012 | 09:30 AM
SlaminSohCivic's Avatar
I have same problem... Help this guy so it helps me to
DamnThatsRexy
Nov 14, 2013 09:49 AM
anth6ny
Feb 28, 2008 06:32 AM
djsire
Nov 9, 2005 02:21 PM
