89 STD(Standard) hatch. Temp gauge issue
Old Nov 14, 2012 | 01:40 PM
89Jayda206's Avatar
Default 89 STD(Standard) hatch. Temp gauge issue
Hey HT EF folks! Its been a while.
A new problem has risen to my concern. My 89 STD hatch temp gauge will not work what so ever. My car runs fine now(thanks to yal EF pros) but when i take a look at my cluster while warming up my car, the temp gauge needle is below the cold line, so i end up turning off and on the car to see the temp gauge will even give the needle a lil movement up. But no movement of the needle at all. So im thinkin like a noob to change the thermostat. Did that and still no movement or any sign of my temp gauge workin properly. So i dont think its my thermostat.
So my question is. - does anyone know what might be the problem?? If so what do i need to do??
I recently got the car to run(it was sitting for about 3 years) and the car is really healthy. But i jus dont like the fact that i cant read the temp gauge. And i dont wanna run into overheating issues due to this problem, and stop me from preventing any more problems.
Btw: the car is bone stock. No funny things done to it.
Thank you so much for reading. I hope you guys can help me. Much appriciated.
Old Nov 14, 2012 | 01:47 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: 89 STD(Standard) hatch. Temp gauge issue
Why don't you check/test the actual sensor?
Old Nov 14, 2012 | 05:40 PM
89Jayda206's Avatar
Ahh 24TEN hows it going bro. Your always the dude to come to the rescue haha.
I never thought about check that. I always thought it was the thermostat. Where would the (temp) sensor be located?, what would i need to do to check/test it?, and what would i be looking for while check/testing it?(like unplug the sensor and see if the motor does a funny thing or unplug the sensor and look at my cluster)
Thanks for throwing me in the right direction bro
Old Nov 15, 2012 | 07:08 PM
89Jayda206's Avatar
Anyone else wanna shed some light? I need the help
Old Nov 15, 2012 | 08:49 PM
jlicrx's Avatar
on the end of the head below the distributor
Dpfan
Apr 5, 2011 11:49 PM
dizzzane
Jul 18, 2007 12:40 PM
h46it
Mar 24, 2002 05:16 PM
