ok sohc ZC almost done! last part.
Old Oct 18, 2002 | 12:47 PM
BeEfiEBuNz's Avatar
Default ok sohc ZC almost done! last part.
I need the ecu now which is better? final answers plz 89 integ LS ecu for 100 bucks or 91 crx si ecu fo 125 bucks which which ? hurry hurryi got 45 mins to make up my mind.
Old Oct 18, 2002 | 01:05 PM
BeEfiEBuNz's Avatar
Default Re: ok sohc ZC almost done! last part. (BeEfiEBuNz)
anybody?
Old Oct 18, 2002 | 01:06 PM
Fishcat37's Avatar
I would say that if the sohc zc motor is stock........then i would get the 91 CRX Si ecu (PM6 i believe) since the sohc zc motor is VERY similar to the D16A6 crx si motor. that's what my friend did when he did that swap in his 88 civic dx hatch, and it worked great.
[Modified by Fishcat37, 4:06 PM 10/18/2002]
Old Oct 18, 2002 | 01:17 PM
BeEfiEBuNz's Avatar
Default Re: ok sohc ZC almost done! last part. (Fishcat37)
yeah i was thinking same thing since my **** is single.. maybe if it was dual i would get a ls ecu hehe ill just stick with the si thanks guys
Old Oct 18, 2002 | 01:35 PM
Stupid Ass's Avatar
Go with the integra... it will run a little rich but it has a better fuel curve... and a higher rev limit.
Old Oct 18, 2002 | 08:11 PM
Iceycrx's Avatar
Default Re: ok sohc ZC almost done! last part. (ridge racer 2)
just get the j-spec zc ecu. u will avoid the engine codes
Old Oct 18, 2002 | 08:44 PM
Bgladfelter's Avatar
Run the 89 Teg. The redline is nicer, and if breathing properly it does help the car.
This is from experience with SOHC and DOHC ZC motors.
MrTodd's Avatar
Default Re: ok sohc ZC almost done! last part. (SOHC NoTEC)
Honestly, the PM6 ecu will give the SOHC ZC plenty of fuel.
There is no need to use the LS - and about the higher rev limiter? It's only 300 RPM higher. PM6=7500 rpm LS=7800 rpm
Just stick with the PM6 - that way you know you have a good solid ECU, the LS could have some glitches.
pxsx
Jul 13, 2008 07:16 PM
BuddhistPriest87
Dec 8, 2006 05:36 PM
Super79Dave
Oct 22, 2005 06:42 AM
quicklilsi
Sep 2, 2004 04:50 PM
BeEfiEBuNz
16
Oct 30, 2002 08:05 PM
