Need a cheap seat bracket help 91 crx
If you have access to a welder you can make your own. I did that using steel bars from home depot. I used the stock sliders but removed the brackets for the stock seat so both sides were completely flat. Then I took some measurements and cut the new steel bars as needed, then welded away. Drilled holes accordingly and bolted the seat in. Bonus is that I got the seat to sit way lower than stock. Cost me less than $25 if I remember correctly.
i have used them in a race car, and have a set sitting in my garage that is unused. i suspect that they are not as good as name brand but I have not had issues with them i the past.
_EF9
Jun 7, 2008 11:35 AM
turbotime
May 28, 2005 07:25 AM
BI8B
Feb 9, 2004 05:06 PM
