Will an obd1 f22 dizzy fit a f23 vtec head?
Thanks for nothin H-T. Went to the local junk yard and did some swappin around on a couple different combos and found what i needed. Holla!!!
Used an old external type coil f22 dizzy housing i think from an early 90's accord with complete obd1 d series "not sure which d series dizzy it was" internals including internal coil with d series distributor cap. Tested it and it works perfectly. I could have just used the internal coil but it was a brand new d series dizzy so i just swapped everything over to the f series distributor. Needed it for my f23 thats going in my civic. Also by the way the f22 dizzy bolts up perfect and runs perfect on a d16y8 head.
Jimster480
Oct 30, 2009 01:36 PM
