energy suspension bushings
have to start threads to be a member so i know this has been talked about 100's of time sorry about that just want to know what you guys think in regards to these bushings good or bad to stiff alternatives to keeping bushing on your ride from bein destroyed from the slammed affect. thank you guys
Yes they do. I do not recall the p/n. Search for rear shock bushings on their site.
Also as mentioned, the maintenance curve goes up, I have had my ES on my 94 for more then 7 years, they are all still in good shape, but I do spend time making sure things are clean and nuts/bolts are tightened to speck. 94
i did hear about the squeeking, but the early wear? i thought those would be way better than oem. my car is slammed and over the years i have just seen wear on my bushings and ball joints tie rods and im looking for an alternative to have a stiff ride with no slushy feeling. i like a stiff suspension. other passangers i really can care less my car my way. i just think polyurethane would be a better alternative to slushy rubber and cracking and tire wear more money i would love to deal with squeek and stiff than sloppy and tire wear more money!!!
I burned the old ones out and then split the sleeves with a hack saw for easier removal. It is a PITA, especially when bolts break or seize to the inner sleeve.
Anyone have tips on installing these bushings. everyone has said improper installations are the main reason they fail. I remeber something about the wieght of the chassis needs on the bushings but unsure of how to do so... any advice is greatly appreciated
Tried an impact and breaker bar already. The rubber bushing is not letting go of that darn bolt.
Does anyone have experiance with red vrs black bushings from ES?
I'm favouring the black bushings as they are quieter and more oem ride without the sqeeking issues.
couple problem bushings in the kit. one of the front lower control arm. they last about 40k miles before they get sloppy enough you pull the tire in and out when jacked up. easy enough to change though. the second is the shifter bushings. i'm not sure why but guys gripe about these. personally i left mine stock and just changed everything else back when i had one of these cars.
Sawzall or an angle grinder.
I'd avoid their RTA bushings as well. That area sees come complicated motion.
what the RTA bushings seem to do at first is increase spring rate. i mean if you bomb hard enough, they do indeed flex, you just have added progressive springs to the mix
it's when they age problems set in. like the fronts they get sloppy around 40k miles. whole design is kind of shitty. you have to grind off your old RTA's and then reuse the metal rod. well, guess what, that rod will be a bit rough from all the grinding you just did. push that through poly and you have created a wear item
hard rubber would probably be the best long term solution, mugen or OE itr. i'm personally not a big hardrace fan. i'm just anti china with parts. rubber is more difficult to install and requires clocking. still, if you plan on keeping the car awhile you'll be money ahead doing the front control arms and RTA's in oem or mugen bushings.
energy wasn't bad elsewhere. rear end held up with over 60k and had zero slop
I got the full energy suspension kit installed on my car a few days ago. Its a stock 94 LS. The reason for doing it was because the old bushings were completely worn out and wearing my front tires quickly. I also had bad axles. I put in brand new axles and changed the tranny fluid. Then I replaced the inner and outer tie rod ends with ES boots. I replaced all the control arm bushings and the shock mount bushings. Then I put in brand new ball joints with ES boots. I did the ES motor mount inserts with new mounts. Then I did the swaybar end links and bushings. Got it aligned and Man this car drives TOTALLY different now. It feels like its on rails compared to before even with the stock LS springs and shocks. The ride is great and I have no complaints about anything
K20A2Timmy
Apr 1, 2004 04:52 PM
