1992-2001 Prelude Huge parts lot, all for $300 Located in Livermore
Old Nov 13, 2012 | 12:49 PM
customs-25's Avatar
Default 1992-2001 Prelude Huge parts lot, all for $300 Located in Livermore
Below is a list of the parts, most parts on top are 1997-2001 the 1992-1996 parts are on the bottom, 925-321-5289. I NEED MONEY AND WILL LET EVERYTHING GO FOR $200 FIRM, I WILL INCLUDE OTHER SMALLER PARTS BUT I DONT KNOW WHAT THEY ARE AND DONT WANT TO DIG THROUGH ALL THE BUCKETS OF PARTS. THE TOP PART OF THE LIST IS 1997-2001 PARTS LOWER SIDE IS 1992-1996 . MY NUMBER IS 925-321-5289
OIL COOLER KIT COMPLETE MOUNTS TO BUMPER SUPPORT NEW FILTER, RELOCATED YOUR OIL FILTER TO THE FRONT OF THE CAR $150
1999 PRELUDE SUB FRAME $50
1999 PRELUDE STEERING SHAFT 30K MILES $45
1999 PRELUDE SIR S SPEC STRUT BAR $40
1999 PRELUDE SIR S SPEC RIGHT HAND DRIVE WIRING COMPLETE FRONT CLIP $50
1999 PRELUDEA/C BOX DASH OUT OF A 30K MILE CLIP NEAR NEW $40
1999 PRELUDE FAN BOX DASH OUT OF A 30K MILE CLIP NEAR NEW $40
1999 PRELUDE HEATER CORE DASH OUT OF A 30K MILE CLIP NEAR NEW $40
E-BRAKE HANDLE JDM 30K MILE LIKE NEW $30
BRAKE BOOSTER OEM HONDAREMOVED FROM A 1999 SIR S SPEC 30K MILES $20
BRAKE FLUID MASTER CYLINDER HONDA OEM FROM 30K MILE CLIP $20
THROTTLE PEDAL WITH FRAME 30K MILE CLIP $30
POWER STEERING RESERVOIR WITH HOSES $25
POWER STEERING BRACKET ALUMINUM 1997-2001 $35
AXLES DRIVER AND PASSENGER HALF SHAFT $40 FOR A PASSENGER AXLE $40 FOR A DRIVER SIDE AXLE WITH HALF SHAFT (DAMAGED WHEEL SIDE THREAD) $40
FUEL LINE AND FILTER 1997-2001 $35
CHARCOAL BOX AND LINE 1997-2001 $30
INTAKE VACUUM BOX 1997-2001 $30
BATTERY HARNESS AND GROUND 1997-2001 $25
ENGINE HOSES ALL ASK FOR WHICH IS NEEDED
1997-2001 HOOD LATCH $20
FIREWALL ENGINE COOLANT HOSE WITH HEATER VALVE 30K MILE $30
GUTTED CATALYTIC CONVERTER FROM A 1999 $30
H22A4 HEAD BOLTS WITH WASHERS $30
H22A4 FULL VALVE TRAIN 70K MILES $30
1997-2001 PRELUDE CARPET AND FLOOR MATS $30
1997-2001 ALUMINUM A/C COMPRESSOR ENGINE BRACKET $35
FRONT REAR AND DRIVER SIDE ENGINE BRACKET $30 a piece
ALUMINUM TRANSMISSION/ENGINE BLOCK COVER 1997-2001 $30
GREDDY TURBO BLUE BOX ENGINE MANAGEMENT 1997-2001 PRELUDE $75
1992-1996 PARTS
1992-1996 fender airbox
H22/H23 ENGINE MOUNTS DRIVER SIDE BOLTS TO BLOCK $35 EACH
NEWER RADIATOR WITH FANS $50
4WS 5-SPEED SI ECU $40
H23A3 ALTERNATOR BRACKET $30
H23A1 ALTERNATOR 105K MILES DENSO $35
STOCK INTAKE PIPE NO BOX $25
H23A3 A/C PUMP BRACKET $30
H23A3 HEADER AND DOWNPIPE WITH NEW O2 SENSOR $40
H23A COMPLETE CRUISE CONTROL $20
H22A OEM OIL PUMP WITH PICKUP 40k miles no damage $40
H23A1 OEM OIL PUMP $40
H23A WATER PUMP $35
H22 WATER PUMP $35
H23 WATER PUMP WITH OIL FILTER COOLER AND BOLT $40
H22a OIL STICKs AND TUBEs $20
H22A AUTOMATIC TIMING TENSIONER KIT COMPLETE $30
H22A ALTERNATOR BRACKET $25
H22A A/C BRACKET $25
Old Nov 19, 2012 | 02:59 PM
customs-25's Avatar
Default Re: 1992-2001 Prelude Huge parts lot, all for $300 Located in Livermore
everything still available
Old Nov 19, 2012 | 07:04 PM
OUT OF ORDER ROB's Avatar
interested in the front strut bar
Old Nov 28, 2012 | 06:46 PM
customs-25's Avatar
still for sale
Old Dec 2, 2012 | 08:31 PM
customs-25's Avatar
Still for sale
Old Dec 4, 2012 | 06:21 PM
customs-25's Avatar
updated the list
customs-25
Aug 18, 2013 03:58 PM
customs-25
Oct 29, 2012 05:02 PM
gulf imports
Aug 20, 2003 11:09 PM
