94 accord shaking problems
Old Nov 12, 2012 | 02:54 AM
Jklango's Avatar
10 Year Member
Default 94 accord shaking problems
Hey, I have a 94 accord that I had an h22a swapped into. I loaned my car to my brother for a year and recently went and picked it back up from him. When I got it I had to drive 400 miles back home and couldn't go over 50 mph the whole way home. All 4 rotors were warped and both axles were clicking bad. I couldn't go over 50 cause it would shake really bad. I replaced all the rotors and breaks and axles and wheel bearings. Also had the tires all balanced. It helped out a lot but still shakes around 60. I work out of town and need to get this fixed. What else do you think it could be? Tie rods? I'm not sure. It cost a little bit to get the work done that I already did. It needed it so I have no problem spending the cash but I just want it to drive straight and not shake. Any help?
Old Nov 12, 2012 | 02:39 PM
76 camaro car's Avatar
Default Re: 94 accord shaking problems
Check your engine and transmission mounts and if they are good I would suspect the front suspension.
Old Nov 13, 2012 | 07:55 AM
eirigance's Avatar
The Balance belt could have broke. that would give you slight dash vibration.
Posted from Honda-tech.com App for Android
Old Nov 13, 2012 | 04:56 PM
HoLoKat13's Avatar
Have you gotten it aligned?? If not that is the number one cause of shaking in any vehicle.
Old Nov 13, 2012 | 08:24 PM
jdowen2's Avatar
You need to have a serious talk with your brother. If I ever have to borrow anything I make sure I bring it back clean and in working order. He also should have brought it to you.
Old Nov 14, 2012 | 03:35 PM
Jklango's Avatar
10 Year Member
Ya no kidding. I drove it 400 miles! Warped all 4 rotors to the point that I had to replace them. Both axels were busted. Even my windshield wipers. Lol he is my older brother too you think he would know better. It shook so bad on the way home I fought to keep in on the road and couldn't hit the breaks cause it made a scary situation even worse.
sneaks
Feb 28, 2010 09:04 PM
ckabee1
Dec 1, 2006 01:10 PM
morana622
Feb 11, 2005 11:06 AM
hankd
Feb 21, 2004 08:57 PM
