5 lug question?
Old Nov 10, 2012 | 07:05 PM
Mikeyb918's Avatar
Default 5 lug question?
I have a 95 gsr that the po and my self are converting to an itr rep sorta lol. I had to do some serious suspension work this weekend and realized my five lug swap is the Jdm swap with the 36mm axels. Sooo is there any major draw backs. Should I look for a 32 mm swap or just wait. My axles are like new so ill have awhile before anything bad happens
Old Nov 10, 2012 | 07:16 PM
allmotorgsrekk's Avatar
Default Re: 5 lug question?
I think the only draw back is you cant use an off the shelf integra axle if something does happen.
Old Nov 10, 2012 | 08:12 PM
Mikeyb918's Avatar
Ok thanks I hear crv axles work but not positive. Welp the axles are in great shape so I'm good for awhile
Old Nov 10, 2012 | 08:26 PM
kchungb17a's Avatar
32mm is USDM and those are harder to come by. If you want this, you can just swap the front hubs with USDM ITR hubs and your GSR axles will fit.
Otherwise yes, the main draw back is that you can't get an off the shelf axle for your application. I'm not certain but I thought it was the CRV/Prelude outter CV joint that is 36mm. Not sure if the whole axle will fit.
williamgasdick
Aug 1, 2013 03:49 PM
lejeaune
Apr 23, 2010 10:24 AM
kazino42
Aug 31, 2009 09:14 PM
MAFDARK
Jan 16, 2009 07:18 PM
Savage211
Aug 25, 2008 06:21 PM
