Honda Accord rough idle, cuts off when u put it in gear slow down or stop. HELP!
Old Nov 10, 2012 | 03:13 PM
bgbeezer's Avatar
Icon3 Honda Accord rough idle, cuts off when u put it in gear slow down or stop. HELP!
Just got a 97 Honda Accord SE. Its been sitting for 2 years and we were pre warned that she had a guy come replace the timing belt and it ran around the yard and cut off in the yard. So we had a mobile mechanic come out for an opinion..he checked it out said it was running good and it prob wouldn't do it again. He did a complete tune up on it distributor cap and rotor, spark plugs and wires, oil change, and sea foam to treat the 2 year old gas. So we leave with the car didnt even get a mile down the road and it cuts off when we had to slow down. It has a rough idle, and cuts off when we slow down, stop, or just put it in gear. I was told it is possible that the idle just needs to be turned up to the timing being off to a vacuum leak. Please help.
Old Nov 10, 2012 | 04:32 PM
jdowen2's Avatar
Default Re: Honda Accord rough idle, cuts off when u put it in gear slow down or stop. HELP!
If it's been sitting for 2 years you have bad fuel. Drain and refill with fresh fuel. Might need a new fuel filter. Should flush fuel rails as well.
Old Nov 10, 2012 | 10:42 PM
doctorbee's Avatar
drain the old gas if you can.
you'll need fresh fuel, maybe some techron concentrate, then take it for an italian tune up (drive it like you stole it)
Old Nov 11, 2012 | 12:38 PM
Quence's Avatar
check for vacuum leak and routing of the vacuum hoses.
mikeyddunn
May 19, 2014 06:21 PM
1984accordowner
Classic Hondas
Oct 25, 2011 01:57 PM
JC316
Feb 10, 2008 09:18 PM
boyracers
Nov 26, 2003 03:21 PM
