92-95 civic 4dr trunk light not working
Old Nov 9, 2012 | 10:02 PM
omgwtf's Avatar
Post 92-95 civic 4dr trunk light not working
Anyone knows how to wire a trunk light for eg8? Mine doesn't work and there's no harness whatsoever...Please throw me some diagram if possible. Thanks!
Old Nov 10, 2012 | 10:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: 92-95 civic 4dr trunk light not working
What do you mean, "there's no harness whatsoever"???
Are you saying there is a trunk light but the 2wire plug is not connected to it?
The trunk light, like the dome light, uses a grounding switch to turn it on, the dome light uses pin switches in the door jambs, the trunk light uses a switch in the trunk latch, power for the trunk light will be the same fuse as the dome lights, [hot at all times].
Sorry I do not have wire colors for the 92-95 Civics, it may be a white/red and blue/black at the 2pin trunk light plug.
The trunk light wiring runs with the rear speaker wiring, fallow the speaker wiring to see if trunk light wiring has been cut back or just tucked back, not sure why anyone would do that. 94
Old Nov 11, 2012 | 12:03 AM
omgwtf's Avatar
I couldn't find the harness. it's seems like they cut it off from somewhere. but thanks for the info!
CoolHandPat
Honda Civic (2006 - 2015)
Jul 30, 2017 01:35 PM
Highny
Lighting
Dec 6, 2016 08:49 PM
aspire
Jun 19, 2009 05:19 AM
RED95EG6
Jan 26, 2007 10:38 AM
sharkytm
Oct 23, 2006 06:43 AM
