LSV my first Bseries build
Old Nov 9, 2012 | 09:49 PM
Jose Mendez's Avatar
Default LSV my first Bseries build
Hi everyone, I am new to honda tech and to the whole B series motor.
I just recently got a B18B1 block for next to nothing $50.00 only 50,000 miles
and in a couple weeks am getting a GS-R head for $400.00 with the vtec kit.
I did some minor research on parts that I'll need to make this work
itr or ctr water pump, itr or ctr oil pump and where I got kinda confused is the
head gasket some say run the b18b1 gasket and other say run the gs-r head gasket. Something about it will over heat if I use the stock b18b1 head gasket.
And am wanting to hit at least 12+cr with dome piston at stock bore and my camshaft have a 282 regrind from delta cams I know to run the cams I'll need better spring and retainers and will be runing stock rods with arp rod bolts and head studs
Is there anything else I might be missing and the swap is going into a 4dr eg
thanks
Old Nov 9, 2012 | 09:53 PM
Default Re: LSV my first Bseries build
Sorry forgot to add on there I got itbs for the gsr head
Old Nov 9, 2012 | 10:53 PM
EusebioSam19's Avatar
Your Gonna wanna get new pistons & rods or shotpeen your rods and get arp rod bolts
If your going oem piston I recommend a p30
Old Nov 9, 2012 | 10:54 PM
Get an inlinepro headgasket 80 bucks
Old Nov 10, 2012 | 02:28 AM
josephcmiller2's Avatar
Consider balancing the assembly if you want > 8000 RPMs reliably. 12+ CR won't necessarily benefit you if you don't have the cams to support it. But it does allow you the option to go bigger cams later. Tuning is a MUST.
Old Nov 10, 2012 | 06:31 AM
TheShodan's Avatar
Moderator
Here's what you need in a nutshell. follow this and life will be good.
http://hondaswap.com/general-tech-ar...ls-vtec-85477/
Old Nov 11, 2012 | 10:19 PM
thanks theshodan I printed the the page so am doing some reading but I saw a picture on there of the pistons it was dome flat and the ones I want to get are a tall dome
heres the link I been looking at
http://www.ebay.com/itm/JDM-HONDA-CI...d903d1&vxp=mtr
Old Nov 13, 2012 | 03:27 PM
blkSi's Avatar
Cheap
Reliable
Fast
Pick 2, and you won't have the other
Old Nov 14, 2012 | 09:27 PM
Originally Posted by blkSi
Cheap
Reliable
Fast
Let's see
Fast
Reliable
And on a budget
But I just order P30 sense there no shaving needs to be done to the rods
Old Nov 14, 2012 | 09:44 PM
nic.baines's Avatar
http://www.zealautowerks.com/bseries.html
Old Nov 14, 2012 | 10:33 PM
this is what I got from the calculator puts me at 12.21:1 CR
Leaves piston to deck 0.013 is this still good enough to put some aggressive cams
VTLX 03R
Jan 8, 2014 01:33 PM
Tong.Y
Jun 5, 2011 09:17 PM
mitchell_2kSiR
Jul 28, 2008 02:18 PM
fergy016
17
Jun 17, 2007 08:29 AM
