b18b timing belt and cam issues
Old Nov 9, 2012 | 09:17 PM
xplayza's Avatar
Default b18b timing belt and cam issues
hey guys im i have a b18b and my timing belt is loose when i start the car its slapping and i thought i just have to tighten it up but as i looked at the cams at tdc the marks werent aligned equally how do i fix this
need answers asap thanks
Old Nov 9, 2012 | 09:20 PM
JuicedUpRice's Avatar
Default Re: b18b timing belt and cam issues
is it possible it could have gotten stretched?
is this your first time,or have you done timing before?
Old Nov 9, 2012 | 09:52 PM
xplayza's Avatar
this is my first time
im just confused on where the cams are unequal how would i set them at tdc where they are equal
Old Nov 10, 2012 | 09:00 AM
fcm's Avatar
fcm
Old Fart
There are more then a few DIY write ups on how to set valve timing/change timing belts here, all you need to do is search, also Google is your friend there are 100s of write ups and more then a few videos, like this one ...
Some more here...
http://www.google.ca/search?q=vidios...CoqgiALRgYHADw
Spoon feeding time is over. 94
Old Nov 10, 2012 | 09:25 AM
there are two arrows on each of the cam gears.you line those up with each other after the crank is aligned tdc.probably didnt line the cam gears up..
Old Nov 10, 2012 | 10:05 AM
el crapitan's Avatar
possibly jumped some teeth. as fcm mentioned, there are a plethora of guides on the net and here. by the time you post something and get a response that may or may not be qualified, you could have found and watched or read one of the many instructional guides and figured out the system and how to fix it. as apposed to just following directions that may or may not be correct.
just a thought. not trying to be an ***
Old Nov 10, 2012 | 12:16 PM
xplayza's Avatar
thanks for the comments and yes i did research but just wanted to know how i would align the cam gears do i take the cam gears out and and align them or is there something else i have to do im really confused and like i said this is my first time i dont wana mess up my whole engine
Old Nov 10, 2012 | 01:48 PM
do you have a service manual for your vehicle?
Old Nov 11, 2012 | 01:36 PM
1_Clean.GSR's Avatar
sounds like you're very confused.. i suggest take it to someone who knows what they're doing or if you have time and the car can sit in the garage... search videos, buy an owners repair manual, and do some research. Like you said .. main thing is that you don't want to ruin your engine.
gravity73
May 6, 2010 03:35 PM
efyou
Jul 1, 2006 10:07 AM
