Help: Rear hub assembly issue
Old Nov 9, 2012 | 07:54 PM
sk8boylou's Avatar
Default Help: Rear hub assembly issue
Just bought a 96 integra GSR a couple weeks ago. Noticed the right rear wheel bearing was shot. When attempting to replace the rear wheel bearing, the inner race of the bearing stuck on to the hub assembly. When trying to get the inner race off i hacked up the assembly that the axle nut goes on. My questing is do they sell a replacement part for what the wheel bearing goes on, I will provide a picture of what park im am trying to figure out is replaceable.
Thanks any help would be great!
Old Nov 9, 2012 | 08:34 PM
kchungb17a's Avatar
Default Re: Help: Rear hub assembly issue
The rear spindle is not available separately from Honda. But if you find one from a part out or junk yard you can replace just the spindle instead of the whole trailing arm.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Nov 10, 2012 | 09:25 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, I would check out your local bone yards, [PicknPull], spindles are under $25 at PicknPull, a new lower control arm will be to $250-$350 about half that at a bone yard. 94
kwae
Honda CR-V & Element
Mar 13, 2016 08:35 PM
axis11
Aug 3, 2013 05:18 AM
bward
Jul 17, 2006 07:40 AM
akteamster
Suspension & Brakes
Nov 22, 2005 07:54 PM
