Key Wont Turn
Old Nov 9, 2012 | 11:19 AM
Thalde's Avatar
Default Key Wont Turn
Hey guys.
This afternoon I tried to start up my car and my key wouldn't turn at all. The entire tumbler wouldn't move, as if it was not the right key kind of thing.
The strange thing is that it worked perfectly fine this morning when I drove my fiance to class.
The only things I can think of is that it froze somehow (no idea how moisture would get in there), the tumbler wore out, or that the keys wore out.
(Background info: the keys for my car only work on the driver door and the ignition, the other door and trunk react the same way the ignition is now)
Any other ideas or helping me narrow it down would be fantastic. Thanks!
Old Nov 9, 2012 | 12:48 PM
shelly17257's Avatar
Default Re: Key Wont Turn
Try turning the wheel as far as you can to one side and see if that unlocks it. Usually that's all it takes.
Old Nov 9, 2012 | 01:45 PM
Thalde's Avatar
I locked, then unlocked, then locked, and once again unlocked the wheel to see if it was the cause but it did not work.
I should also add that I took it out of park and back in several times to see if that was causing it as well.
Old Nov 9, 2012 | 01:57 PM
jdowen2's Avatar
Your switch is probably bad.You may be able to take it apart and clean it. Are you parked on an incline? If so, have someone help you rock the car back and forth while trying to turn the key.
Old Nov 9, 2012 | 09:17 PM
Stagerguy's Avatar
I had my ignition switch freeze up, probably similar to your situation. I pulled the ignition switch out and took it to a locksmith. It was in bad shape but they managed to get it working, at first when I re-installed it, you had to turn the key back (ignition off) but you couldn't pull the key in one motion. After about a month it started working just like new. I believe it cost me $65. A new ignition switch is big $$$
Old Nov 9, 2012 | 11:33 PM
MARINEDEVIL03's Avatar
if the key is slightly bent that might be the problem, it happened to mine
FTNW
May 27, 2012 12:14 AM
nascar8309
Honda Civic (2001 - 2005)
Nov 19, 2010 06:22 AM
1sikhatch
Apr 9, 2010 08:41 AM
Hazem
15
Dec 16, 2004 01:54 PM
illusion
Jan 1, 2002 07:29 PM
