RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP?
Old Oct 18, 2002 | 09:47 AM
RotaryBzzz's Avatar
Default RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP?
Ok...my flame suit is on...I'm ready
The other day, i was reading how putting an early rx7 air flow meter into 1.6 or 1.8 Miatas yield BOLT-IN, PLUG-IN, no tuning needed dyno proven 5 hp to the wheels - with dynojet dynosheets showing it. The article, written by SCCA dudes, was quite thorough. On thing was that this conversion did run lean in some spots on the curve but overall it was extremeley drivable.
I was wondering what your thoughts would be on any similar applications for a prelude AFM into an Accord (or any other combination). Apparently both the miata and early Rx7 use flap-type air flow meters and the Rx7's AFM flowed much more than the miatas. Even late model miatas experience 5-6 hp gains. I'm at work and I don't have my manual in front on me. I think Honda uses wire-type AFM's...not sure if that would make any differences. Any ideas pop into your heads?
Old Oct 18, 2002 | 10:53 AM
carolinaACCORD's Avatar
Default Re: RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP? (RotaryBzzz)
our cars have MAP sensors to read the intake pressure. basically all hondas use the same type sensor, so i doubt it would gain anything.
[Modified by carolinaACCORD, 2:53 PM 10/18/2002]
Old Oct 18, 2002 | 10:58 AM
GimpyAccord's Avatar
Default Re: RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP? (carolinaACCORD)
yah you're confusing MASS AIR METERING with SPEED DENSITY.
on MAF equiped cars (like RX7, Mustang, etc) a new MAF can yield results....
speed density (uses a MAP) is a different story
Old Oct 18, 2002 | 11:42 AM
SOHCArchangel's Avatar
Default Re: RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP? (GimpyAccord)
omg
hondas DONT HAVE MAF sensors
Old Oct 18, 2002 | 01:21 PM
Default Re: RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP? (SOHCArchangel)
has Honda ever even made a mass-air metered vehicle????
Old Oct 18, 2002 | 01:26 PM
RotaryBzzz's Avatar
omg
from above: "i think honda's use wire-type AFM" ....right idea, wrong terminology.
That's why there was a "?" on my title. I'm looking for ideas. Chill.
H22AEX
Aug 20, 2013 03:14 AM
AGENT 99
Aug 10, 2004 08:10 PM
accord_ex90
Feb 2, 2002 06:39 AM
dmfare
Sep 12, 2001 05:24 AM
