fs 01 integra gsr built b20/vtec
Old Nov 9, 2012 | 07:02 AM
91boostedSi's Avatar
Default fs 01 integra gsr built b20/vtec
found a wrx im wanting to get so trying to downsize the cars i have
01 gsr with 80k on shell, 50 miles on the motor
Bottom End:
all machine work done by baines machine in lafayette in
-micropolished crank
-balanced rotating assembly
-shotpeened ls rods
-supertech 12:5.1 piston
-arp rod bolts
-acl standard main and rod bearins
-oem itr oil pump and water pump
-arp head studs
B16 head
-supertech valvetrain
-buddy club spec iv cams
-blackworks race cam gears
-golden eagle ls/v kit
-new valve seals and valve guides
Randoms
-edelbrock performer x intake mani
-omni power 70mm tb
-skunk2 alpha header
-innovative mounts
-comp stage v clutch
-act flywheel
-dsm 450s w/resistor box
-trans has b16 1-3 gears, 4th and 5th
-usdm itr cluster
-15" drag dr16s with khumo tires
-omni power coilovers
-omni power lcas
-omni power camber kit
-omni power adjustible a arms
it does run, but needs a dizzy. also fourrh gear and reverse are out. fourth goes into gear but just revs like its in neutral. asking 4k obo. it has that in parts alone and id rather it it go to someone who wanrs to finish it rather than part it out. call text 765-585-4693
Old Nov 10, 2012 | 07:42 AM
mitchchizo22's Avatar
Default Re: fs 01 integra gsr built b20/vtec
Trade for an 05 repsol 600rr? Forsale thread is on here
Old Nov 10, 2012 | 03:05 PM
civic_1's Avatar
If you have this in 2 weeks ill pick it up! Do you have any more pictures of the body and interior? Please pm me thanks
-Jon
Old Nov 10, 2012 | 06:36 PM
$MIKE$'s Avatar
4gs damm thats a deal
simplejackk
May 9, 2012 06:32 PM
vtecJUNior
53
Jun 2, 2010 01:14 AM
