Need Help geting PR EF x-member ASAP...
Old Oct 18, 2002 | 09:44 AM
crxgurlllll's Avatar
Default Need Help geting PR EF x-member ASAP...
in the middle of a turbo install and need to get one of these ASAP(please done reccomend Jimfab or z10) if anyone knows any local shops(so cal) that has one in stock or perhaps personally knows Gil and can hookup something today let me know.... Thanks for any help you can provide.....
Autolink has one but its on Hold for someone else
JHP is Out of stock
Place Racing has a couple but they are spoken for
Old Oct 18, 2002 | 09:55 AM
Default Re: Need Help geting PR EF x-member ASAP... (eraser)
bummmmmmmmmmp
Old Oct 18, 2002 | 10:39 AM
Doodoo's Avatar
Are you doing turbo on a B-series? If so is it a A/C positioned turbo? If it is you can have at the largest a 2.5in" squiggly DP piece made that will fit. Temporarily. I would give you mine (for a DRAG3 manifold) but I haven't gotten my crossmember yet either.
If you have it no A/C mounted then you should have room.
Old Oct 18, 2002 | 10:44 AM
Default Re: Need Help geting PR EF x-member ASAP... (Doodoo)
the downpipe for the exhaust gets in the way
Old Oct 18, 2002 | 01:27 PM
bump
Old Oct 18, 2002 | 01:53 PM
Speed PHreak's Avatar
For your enjoyment
Stock x-member with some "mods" - This is with an LS and a DRAG III kit.
[Modified by Speed PHreak, 5:54 PM 10/18/2002]
Old Oct 18, 2002 | 02:14 PM
EL Vap133's Avatar
Default Re: Need Help geting PR EF x-member ASAP... (Speed PHreak)
That has been tried and still no luck....
Old Oct 18, 2002 | 03:20 PM
fawggggin a bump
Old Oct 18, 2002 | 03:30 PM
FUP23's Avatar
New User
i cut the living **** outa mine ..theres not much left in that area of my dp
RA050826
Mar 19, 2008 11:28 PM
89efDUSTY
Jan 19, 2008 09:23 PM
jdmef-9
Aug 25, 2006 03:02 PM
HatchBox
Jul 11, 2003 01:16 PM
