Won't start... nothing working
2001 Accord ULEV model, 160k miles
So tried to help my brother out and thought it was an easy fix lol but just can't figure out why it wont start. I mean nothing... the only thing that lights up are the brake lights when pressed. instrument panel, dome light, headlights, locks, etc. non existent at this point. When the key is turned.. nothing no clicks or cranks, just dead air.
Up to this point the car was running fine. So today he comes over and chills in his car listening to his ipod plugged into the cig/lighter and radio with the car off for a little while. Gets out and a few hours later wont start back up. It clicks at this time, but the clicking is coming from the passenger side fuse box. We try to jump start it and the horn just blows like crazy. So we go pick up a new battery (he told me that a few months back a mechanic told him that he needed a new battery soon) I remove the horn relay and connect the new battery. I put the horn relay back in the fuse box under the hood and the car does nothing. As I mentioned brake lights work when pressed but that is it.
So I go through the fuses and find that the radio/cig lighter fuse is blown, I think at this point I figured it out, replaced it. Still nothing happening same deal when starting it.
I mean is it something with the anti theft since it is part of the radio, and the horn blowing when trying to jump it earlier? Or was the battery so dead that it couldn't charge the system components like the radio and blew a fuse and I'm missing another, or the main relay?
The thing is if it was the main relay there would of been some premature signs not just bam car completely dead right? I don't think it is the ignition coil because same thing there would of been some obvious signs before this point?
Should I try hitting the starter while starting it?
yeah, might have missed a couple fuses but the passenger side panel is where I found the radio/cig lighter fuse blown, it was a 20.
Can a fuse be bad even if it is not blown?
It can be the main relay. Have you taken it out and checked the solder on all the joints? It's sort of a pain to get to it (personally, i just did it and it's in a really hard place under the steering column and I had to position my body very awkwardly) (99 Accord v6) Give that a shot?
I have a 2001 Honda Accord, took the battery off for 2 hours and put it back and now a small red light is flashing to the left of the steering wheel.
Please can some one help....
- The car won't start
- The battery seem to be fully charged, it won't crank
- front lights and back light star flashing
FlewByU352
Sep 22, 2011 12:15 PM
em1gangsta
Jun 29, 2008 01:29 PM
